Old 06-13-2014   #1
import_boi
Drives: ae86,2ga,
99 gsx ecu on 6 bolt????
Hey folks I'm confused about how this ecu worked on my 95 gsx with a 6 bolt swap.
Ecu is black #md359402
How is this ecu powering the car?
I was gonna send my ecu into ecmlink to get chipped but if this compatible with open port than I might just go that route.
import_boi is offline   Reply With Quote
Old 06-13-2014   #2
Re: 99 gsx ecu on 6 bolt????
I dont think its that uncommon actually.
Old 06-13-2014   #3
import_boi
Drives: ae86,2ga,
Well that's good to know.
Old 06-16-2014   #4
typeRA
Drives: 22b bro
I run this, but I'm using a 98 spec wiring harness. You'll treat it as if you were doing a normal 6 bolt swap since the 97+ use a cas too.
typeRA is offline   Reply With Quote
