Old 10-17-2014   #1
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
CV axle nut really stuck, need help asap!!
It isn't on a DSM but I figured someone might have a trick. I have tried propane and mapp gas to heat it up. I've broke two 1/2" drive ratchets. Bent the crap out of a cheap cheater bar. Shattered the head of a thicker cheater bar. An electric impact didn't do anything. Used lots of pb blaster.
I dont have air tools and really dont want to fork out $150 to buy acetelyne and oxygen and rent a torch.
Does anyone have any other idea's? I'm stumped.
mitsukid124 is offline   Reply With Quote
Old 10-17-2014   #2
b00sted_spyder
Re: CV axle nut really stuck, need help asap!!
Breaker bar with 5 foot thick long pipe should do the trick.
Old 10-17-2014   #3
mitsukid124
I tried that and it snapped the 1/2" drive part at the socket.
Old 10-18-2014   #4
93gtpeater
Drives: cbr 1000rr repsol
Put some heat on that bitch...... Or buy real tools. Lol
Old 10-18-2014   #5
Take a die grinder and cut the nut.
Old 10-18-2014   #6
mitsukid124
I will have access to a full shop tomorrow that has an oxy- acetelyne torch and air tools. So I'll see if that helps. I currently have nothing bigger than 3/8" that isnt broken from various attempts haha.
Old 10-20-2014   #7
I had a stuck axle nut, broke my craftsman 1/2 18" breaker bar, got warranty replacement because of an obvious mfg defect, got a new one plus 5' extension pole and got the nut off just fine.
Good luck.
Old 10-20-2014   #8
Careful with the Oxy torch, I use a MAPP torch and it works good. Throw some heat at it and then grab the impact and off she comes.
Old 10-20-2014   #9
twack
It was a auto get over it
twack's Avatar
should have hit me up cole you know i got toys
Old 10-21-2014   #10
dsmreck
dsmreck's Avatar
Drives: 98 gsx
impact
