Old 03-10-2018   #1
CarPsyco84
CarPsyco84's Avatar
Re: My ultimate streetcar
Since I've always been too cheap to pony up for some expensive sportscar, I figured I'd make a car I knew do everything I wanted out of a car. It's been a hell of a lot of work, disappointment, and learning. But for the first time. I have a dsm that makes me smile every time I drive it, not just a single purpose drag car but a street car, that can take corners with the best of them, and pick on stock cars like they are just some Camry.
Build List:
Engine:
6 Bolt block that's been O-ringed, had about .01" of ring protusion
ARP main studs
Kiggly Main Girdle
Moroso 6-bolt pan with a few tweeks
Eagle 6-bolt rods w/22mm pins
Wiesco 7-Bolt HD1400's 9.6:1 CR
Stock 6-bolt head w/Kiggly HLA
Not even sure what's in there for valve springs Brian Crowers maybe?
BC280 Cams w/stock gears
Cometic .046" MLS Head Gasket (for about .04" squish)
Topline oil pump/front cover with straight cut gears.
Cleaned up/ported the main passageway to the front oil gallery
90’ OFH with factory 90’ cooler, mounted between front mount and rad.
Ported oil pressure relief valve
Balance shafts are deleted (not even an option in this block because it clearly spun 1 of the bearings bad)
DSMLink V3
R.E.E.F. Street intake manifold
FP Bolt-on Exhaust Mainfold
Some tubular O2 that I have cusomized w/321 pipe to a 38mm tial flange
Tial 38mm with the blue/blue spring combo
FP Black turbo
FP 4" Intake for SD
ETS Race 4" Intercooler
FIC 2150's
ARC-2 CDI box
Factory Coilpacks that I rewired w/14 ga wire
ACT Streetlite Flywheel
Southbend SS-X plate with the OCE (Exedy) disc
Chassis:
91' Talon body
Carbon hood w/vent
Rear toe Eliminators
rear poly bushing including mustache bar
Stock 4-Bolt and axles
23 spline T-case, stock driveshaft
17x9 +45 Bronze RPF1's wrapped with 255/40 Z2 star spec's
1/2" spacers on the rear wheels
Modded rear tailing arms for wheel/tire clearance.
JIC Magic Coilovers that have been mullerized
Walbro 450 (rewired obviously)
3/8" Fuel line to a Fuel lab 818 filter with the 6 micron cartridge.
Aeromotive FPR
CX Racing Aluminum Radiator
3.5" exhaust with magnaflow oval muffler
3" downpipe
Rest of Car:
Sparco Speed drivers seat
O2 gauge in factory oil pressure hole
3 gauge A-piller with oil pressure/Oil Temp/Boost
Sure I'm missing a few things, but that's most of it.
So on to my current status. Reworking a different block.
One of the main issues I believe plaguing my old motor, was the oil delivery setup. Sure pressure was fine when I drove it normal. But spending some time above 7k, and add some corners in the mix and I caught the gauge twitching alittle. This didn't lead to iminent failure. But 3 sets of rod bearings wrecked on cyl #1, suggests oil delivery is a serious possibility. So this winter I am trying to head off any oiling issues short of going dry sump (anyone want to borrow me 5500 bux?). I am doing some oiling mod's learned from jafomobile. Grinding the oil delivery hole smooth. I will be adding chamfers to my crank.
So speaking of cranks. After wrecking a couple, I was on the hunt for another one. This time armed with a 1-2" mic and knew where to measure the rod pin. After looking at a handful of them. I realized my eye alone doesn't tell the whole story. Even the best least abused looking cranks did not measure within spec, they all showed wear on the compression stroke part of the journal (were undersize just in that 1 spot). So with this I decided to have 1 of my old cranks ground 01" under.
And of course, I got a case of since I'm in there's... Girdle, arp mains, align honed (at least checked), deck and fire ring job.
Current question lately is what to do about the oil pan. Can we get a group buy on pan's by Mark? I am seriously considering getting a moroso but I question fitment in the car, looks like it could be fun to fit on the car. Anyone ever use one? Thoughts??
ID:	16941   Click image for larger version
ID:	16942   Click image for larger version
-When in doubt, Moar RPM.
Old 03-10-2018   #2
SlowWhite
Been there, done that.
SlowWhite's Avatar
I run a Moroso pan on my 2g.
Make sure you get new not old. They revised it to fix a clearance issue.
Not much else to say really.
There are a few oil mods you can do.
Filter housing has one, the oil port in the head has one, and HLA also you can do. Just Google the topics
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 03-11-2018   #3
wow nice. I swear there were more 1ga white cars produced than any other.
Old 03-11-2018   #4
CarPsyco84
CarPsyco84's Avatar
Thanx for the tip on the pan revision, I did not know that.
I have seen most of the other tricks also, filter housing was already done. Noticed, cause this engine never had crazy high pressure at high rpm like other 6 bolts ive had in the past.
I've read about the oil delivery hole pocket in the head being modded not sure if that's the same trick your thinking of.
And I have an HLA in the garage ready to go in the head. I'd love to know exactly what's needed and what's overkill. But playing science experiment with the bottom end is really too much work and money to gamble with.
Old 03-12-2018   #5
SlowWhite
SlowWhite's Avatar
http://www.dsmtuners.com/threads/4g6...rt-mod.341028/
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 03-13-2018   #6
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
I told you about the revised moroso pans, they use to leak like crazy...most likely from a weld process? not One hundred on that. Glad to see you documenting your dream build. I think itll swiftly become know in the car community again!
Old 03-16-2018   #7
CarPsyco84
CarPsyco84's Avatar
Everything is going to plan. Blocks at Gosh, for deck and oring. Since I was next door. I put a timeline to this heap of parts to go on the dyno.
While that's gone, time to clean up all the little things. Bigger fuel line from the tank up, bushings in the shifter, replace the bell housing, and take the grinder to my turbine housing. I've decided I'd rather try and make a single 450LPH pump work than try to stuff 2 in there and suck air below a half tank. Which means I need more injector and the bigger line.
Old 03-16-2018   #8
We will have to meet up sometime since we are neighbors. (i'm in Blaine)
Old 03-16-2018   #9
Ha, looks a lot like my old build over the years(Muellerized JIC's, FP turbo, oil mods, toe eliminator, etc.) I had really high oil pressure on my 2.4 mostly because I didn't put in oil squirters, which I would definitely would've added if I had kept the car. I ended up porting the relief as far as possible to get it to the right range. Do you have low oil pressure just at idle, or all the time?
Old 03-17-2018   #10
CarPsyco84
CarPsyco84's Avatar
The oil pressure is actually pretty good, till it sucks air. It's 15-20psi at idle, and around 80 at higher RPM's and seems to flatten off without overrunning the relief valve. But I ran .003" clearance bearings so it plenty of room to escape.
It had issues on say a left handed clover leaf, the one time in particular I remember I decided to exit in 2nd, so it was at 6700ish for a lil bit, then I come out on the throttle, I remember the pressure gauge jumping around, and thinking, oh wire must be loose... You know how you justify away major issues, well I can say looking at the parts the wire to the pressure gauge wasn't lying.
So I'm hoping an HLA, venting the block, and a bigger maybe better pan will help the oil drain back, and the extra volume provide more forgiveness for spirited left turns. Cause this was with tires that had the grip level of a brick before, now with 255 wide 200 class tires it really dives around corners. I know people have this theory that DSM's can't corner, and they really don't do well stock. But good coilovers and toe eliminators totally change that.
Old 04-27-2018   #11
CarPsyco84
CarPsyco84's Avatar
Been a busy past few couple months, but I have a few updates for the dsm. In an effort to help this tiny 8cm housing breathe better with the huge compressor strapped to the other side, I took the grinder to it. I tried to open up the narrow part just after the waste gate vent as much as I dared. Manifold I didn't do much more than take the gating off a couple of the runners and smooth things out, didn't figure there was much to gain there.
Block is back from Gosh. Did a nice job with the rings on that, don't mind the hone job, it wasn't mint to start with, making hp, and piston sealing has never been an issue with any dsm I've had.
And I don't know about anyone else, but I have yet to find a good drain flange for a mitsu housing that actually worked. So I did what any machinist/car guy would do, I made my own. It's 1/2 NPT, I made it wider than the 1" ones you normally get, and I stopped the threads just short on the ID so the flange side hole would be smaller, to give it more width to seal on the gasket. Along with giving it the proper hole pattern to make it fit the mitsu without a mile of slop. I ended up using 7075, hopefully it doesn't corrode too bad. If I had a piece of 6061 I would have just used that. Reassembly should start next week. Still have to install the fuel line setup, and run some better wire from the CDI box to the coil pack so I don't loose any spark energy from that.
Oh, and does anyone have any 1.5" 321 stainless pipe around? Looking to redo the short part to the wastegate flange on this O2 housing with the right material so I don't have to re-weld it weekly.
ID:	17039   Click image for larger version
ID:	17040   Click image for larger version
ID:	17042   Click image for larger version
Old 04-27-2018   #12
I like that drain flange, i need to buy one. I'd like to make a complete .7mm+ drain line for my new turbo once i finish with the 16G.
Nice work.
Old 04-27-2018   #13
CarPsyco84
CarPsyco84's Avatar
My drain line is 3/4" push lok hose, have a 1/2" NPT to 3/4" barb that I get from Ace for like 7 bux, and I am going to have an alum barb welded to my moroso pan now. I'm not sure how picky the FP black is with oil returns being that it's a mitsu style housing, but I've ran a garrett that was so I don't want to start going small again and create problems.
Old 04-28-2018   #14
Nice.
Old 05-02-2018   #15
Looking good, Mike!
Old 05-05-2018   #16
CarPsyco84
CarPsyco84's Avatar
So what do people run for catch cans? I am going to have 3 3/4" lines to vent now, and doubt this cheapo can I got is up to the task. I know catch cans are not all created equal. I'm gonna need one that does some real fume separating now that I'm venting directly off the block.
Old 05-06-2018   #17
What is your new line setup?
Old 05-06-2018   #18
CarPsyco84
CarPsyco84's Avatar
I have 2, 3/4" lines off the vc, and 1 off the back of the block. Only using heater hose for mock up, once I have a perminant solution I will get some decent Parker hose.
I've been trying to avoid using manifold vacuum and intake to vacuum the crankcase but I suppose if I have a real catch can instead of an aluminum cup with fittings in it, I might not get that much oil in the intake tract.
I also don't want to change my oil every thousand miles either cause it 's so contaminated with crap from the fuel. So like usual, the right solution isn't the easy or cheap one. But I'm thinking the 2 can method may be the way to go.
Old 05-06-2018   #19
CarPsyco84
CarPsyco84's Avatar
Delete, I double posted
Old 05-07-2018   #20
I'm going to use a 2 can setup, Calan catch can is the best on the market hands down. I have his original can and I'll have another here soon.
he also goes by JCSautomation, but if you search calan catch can on tuners you will find all the info you need.
I plan on doing the same setup as you, 2 off the VC and one off the block. The single line will be using vacuum off of the intake and the 2 lines off the VC will have vacuum from the intake (pre turbo).
