Old 11-13-2004   #1
joem
Drives: 1991 Talon awd auto
Question Should I or Shouldn't I that is the question
I'm starting a colt project. The question is should I use the parts of my car or part it out and start all new and sell it whole.
joe
Old 11-14-2004   #2
john
Business as usual
john's Avatar
What are all your mods? I would sell it whole unless you have way too much money in it. Go bigger and better.
97 Viper GTS
Old 11-14-2004   #3
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
I don't recall what car you have... if it's FWD, use it. If it's AWD, part it out. FWD is more valuable to you, and AWD is more valuable to everyone else.
Old 11-14-2004   #4
joem
Ported scm-61 turbo(no creep never boosted above 17), super-afc, 660 denzos inj. koni adjustables all around, 6 bolt motor bal. shaft removed with QPRs cut down shaft, 3" turbo back exhaust, big brakes, strut bars front and back,
2g swirl rims, 10.4 talor wires, boost guage,
half-assed installed front mount, new windsheild,
new timing belt and all timing parts, new water pump. new head gaskit, 107000 miles, runs good,
switchable transfer case, trans shifts good no grinds, 2600 act, 99% rust free, ported 2g manifold, boost controler, and other thinks i can't remember right now.
ADDED!!!!!!!!!!!!!!!!
255hp walbo fuel pump
if sells at my price will add eprom ecu with the chip for the car
2g mas
2g big brakes
1mm oversized valves and guides and spare head to be built
new valve cover gasket
shaved valve cover powder coated black
joe
