Old 11-27-2004   #1
jpretz
Send a message via AIM to jpretz
Boggage
Okay... I have a 93 Laser AWD with the following mods:
HKS Filter
Ported Head
Ported 02
Ported 14B
Ported 2G Mani
3" TurboBack Exhaust
Elite MBC
So... on with the problems...
Hokay. So when I'm at WOT, it seems to bog @ 5-6k (bogs like hitting rev limiter). Also it seems to creep after a bit. I think it also bogs even when it doesn't creep. I turned down the MBC to 10 PSI and it still does it!!! Fuel cut? I don't know whats going on! I know you all are the Dissem experts... any ideas?
Thanks,
Jayme
jpretz is offline   Reply With Quote
Old 11-28-2004   #2
jpretz
Anyone?
Old 11-28-2004   #3
Kougar
Drives: 06 RSX
It probably has something to do with your exhaust being cheaper than mine....
Then again, it could (but very doubtful) be a spark issue. Mine never creeped, but when I got on higher boost it hesistated like you describe. Turns out one of my spark plug connections was 100% secure to the plug. I'd check for firm connections. Like I said: Doubtful, but possible.
Old 11-28-2004   #4
Change your plugs and get some fuel control on it. You have a fair amount done for no fuel control.
Old 11-28-2004   #5
jpretz
They are fairly new (3 months) NGK Plugs...
What do you recommend fro fuel systems? I'm only planning on running low 13s. Nothing too biig
Old 11-29-2004   #6
Pump, injectors, afc, maybe a mas upgrade.
You could be experiencing spark blowout (try gapping down the plugs tighter) or since its so cold, you could be experiencing MAS overrun.
Old 11-29-2004   #7
Fairly new plugs means nothing. Some of these guys change there plugs as often as they fill the gas tank. Plugs are cheap enough and easy enough to pull, look, and even swap.
Old 11-29-2004   #8
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Check your wires also. Are they a cheap brand or oil soaked? You could try misting the coil/wires with a cheap spray bottle. If they are arcing out you will see the spark or hear a nice ticking sound.
Old 11-29-2004   #9
I would give a good bet on spark plug wires. Is is like a stuttering uinder full boost? Just sounds like its missing at a certain rpm? Thats what happened to me along time ago and I found out it was the wires. Get some taylor wires from summit and see what happens.
Old 11-29-2004   #10
I would at least either rewire your stock pump or get a 255 lp pump. A SAFC would be a big benefit too. You should be able to hit low 13's w/o the SAFC though. For high 12's I would recommend one though.
Old 11-29-2004   #11
Spark plugs, wires, fix boost leaks and datalog it.
Old 11-29-2004   #12
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
mang that shit creeps to 20 psi
Khadgar is offline   Reply With Quote
Old 11-30-2004   #13
jpretz
Kyle is correct... We also noticed that it's creeping! But I thought the ported O2 shoulda fixed it?
Old 11-30-2004   #14
No you need a bigger flapper so the air can get out of wastegate hole versus following the nice turbine outlet hole. Porting the O2 will just help spool and if you did the flapper upgrade then it might help creep.
Old 11-30-2004   #15
Depends which part of the O2 you port. If you work on porting the wastegate channel, then you can help get rid of creep. If you make the main exhaust channel huge, then you make it easier for it to creep.
Old 11-30-2004   #16
hmm..still creaping huh? That o2 housing is pretty much as ported as a 1g can get, maybe we can look into the larger flapper or a ported 2g option.
Old 11-30-2004   #17
2Gs might have a bigger wastegate channel while the 1Gs have a bigger main exhaust channel. So a ported 2G might help or an EVO 3 O2 housing. Or just do the flapper.
