Old 12-04-2004   #1
Wizard50369
Send a message via AIM to Wizard50369 Send a message via MSN to Wizard50369 Send a message via Yahoo to Wizard50369
Electrical Problems
My alarm, my dome lights, the power door locks, and my stereo wont come on. Using my stereo for the testing since its easiest to get to I tested voltage at the Battery wire (the one that goes directly to the battery) and came up with only 1.3 - 1.4 volts. Not 13-14. Tested the ignition wire and it came out to 13 volts. If I plug my stereo directly to the battery and not use the stock wiring, it works.
All fuses are ok and are getting power to them. What could this be?
Its in a 1G by the way.
Ignorance Is Not A Virtue
Wizard50369 is offline   Reply With Quote
Old 12-04-2004   #2
Sean485
Guest
Tournaments Won: 6
Posts: n/a
What made it start doing it? Change anything lately? Did you check to see if your getting a good ground to the stereo?
Old 12-04-2004   #3
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
check the ground on your alternator and make sure your alternator is good. I had that same problem. THose were the solutions.
- Josh L.P.
Old 12-05-2004   #4
john
Business as usual
john's Avatar
I would say alternator fuse (80 amp in the engine bay). But you said that you already checked them... Did you spark anything? Is it just an all of the sudden problem?
97 Viper GTS
Old 12-06-2004   #5
Wizard50369
I checked the ground on the alternator visually and it seemed ok. The few things I did to the car was replace the transmission and rip the interior out to clean it. I took the door panels off, and the center pieces. The only wires I unplugged are the ones in the door. It couldnt be the alt. because my battery stays charged, my head lights, my windows, and my dash lights work.
The horn does NOT work either. what a bitch that is in traffic
Old 12-06-2004   #6
LightningGSX
Hellbound
Do you have a factory alarm or an afterrmarket one?
-Nulli Secundus-
Old 12-06-2004   #7
Wizard50369
Factory alarm
Old 12-10-2004   #8
Wizard50369
Woo hoo! fixed it. But when i was driving home (before i fixed it) the dash wouldnt illuminate, the DSM gods hate me. Ill fix it some day.
