Closed Thread
Old 12-15-2004   #1
x1genx
x1genx's Avatar
Drives: 90 1g awd
Send a message via AIM to x1genx
engine swap problems
ok im having problems remember where certain things go and the chiltons is not helping.
As far as my fuel rail goes there are two vaccum lines one that runs right off the fuel press. reg and one right before it. During the swap i yanked off all the emisions garbage but on thepressure reg. i left those two lines... where do they go? do I cap them off and if they ran to something else do i cap them off too?
Also there is a ground wire that is located on the firewall right next to the brake /clutch fluid resovoir (to the left) where on the motor do i need to place this I cant find anything in pictures or the manual for it.
thanks
x1genx is offline
Old 12-15-2004   #2
Re: engine swap problems
Try again with the proper grammer and information (year, engine, model, mods, etc.) so we can help you.
1ViciousGSX is offline
Old 12-15-2004   #3
The ground wire is probably the one that goes on the intake manifold. The line for the fuel pressure regulator goes to a solenoid on the firewall, there should be 3 little black ones.
JET is offline
Closed Thread
