Old 12-23-2004   #1
jd1828
Send a message via AIM to jd1828
need help! car wont start
ive killed the battery 2 times trying to start it. it turns over and sputters a little but wont start. i checked the battery and it is still good. i was just out driving it last night and it was fine.
jd1828 is offline   Reply With Quote
Old 12-23-2004   #2
john
Business as usual
john's Avatar
Re: need help! car wont start
Year? Turbo???
97 Viper GTS
Old 12-23-2004   #3
john
Business as usual
john's Avatar
Spark??? Fuel???
97 Viper GTS
Old 12-23-2004   #4
jd1828
its a 96 turbo. im not sure about spark or fuel. its outside and it too cold for me to work on it very long. im thinking that there might have been moisture in the fuel lines that froze.
Old 12-23-2004   #5
I've had the same problem with my daily driver yesterday and today. Had to get it in a warm garage or jump start it.
Old 12-23-2004   #6
jd1828
any idea why? im moving back to duluth next month and i want to make sure this doesnt happen again.
Old 12-23-2004   #7
Get your battery load tested. I've drained my battery twice in two days and I'm almost positive that it's shot now. (Had it in the car for 5.5 years since I've owned it.) Also check the battery terminals. Clean them or replace them if they're corroded and/or rusty.
Old 12-23-2004   #8
jd1828
did all that. that was the first stuff i checked. killed the bat 2 times. then brought it to checker and tested it there. it was fine and they also charged the battery again.
Old 12-23-2004   #9
TGPilot
TGPilot's Avatar
Send a message via AIM to TGPilot
You say it is too cold to work on it? Just how cold is it outside? I didn't see in your sig or name where you are from. It is entirely possible you have water in your tank and have a frozen or occluded fuel line. Also most fuel pumps won't show they're dieing until it gets really cold outside. Check for fuel.
Showing N/A cars just how slow they are at 6000' above sea-level!
1990 Pontiac Grand Prix Turbo Coupe 222HP / 320ft.lbs @ 3700 RPM
1990 Pontiac Grand Prix Turbo STE 222wHP and 280ft/lbs @ 3850 RPM
TGPilot is offline   Reply With Quote
Old 12-24-2004   #10
john
Business as usual
john's Avatar
He is in MN. The temps lately are in the single digits.
97 Viper GTS
Old 12-24-2004   #11
Or in the case of this week, below zero.
Current temps in the US:
Old 12-24-2004   #12
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Your coolant temp sensor is most likely bad. Change that and it should be just fine. If your coolant temp sensor is bad, it will not tell the ECU to use a cold weather enrichent fuel map. And if I remember right, if the sensor is bad the ECU will think the outside temp is like 600 degrees F or somethink like that. If you can get your car to start, most likely it will run like shit for about 40 seconds then it will bypass that fuel map and go into a alternate 'default' map. Once this happens you will see a CEL and it will run decent but not great. And when the car is warm it will start back up great, but as soon as it gets down to outside temp again it will do the same thing.
Try that out, if its the culprit as soon as you replace it the car will fire up like a charm.
CRAIG
Old 12-24-2004   #13
TGPilot
TGPilot's Avatar
CRAIG
WOW...thanks Craig! I didn't realize that the cold start was so dependant on the temp sensor! That takes it a step farther than a frozen line. Defenitely good to know if I have a similar issue.
Old 12-24-2004   #14
jd1828
I put some IPA in the tank and bought a small oil pan heater. I just got home so Ill give it a few hours for the heater to warm it up. Then Ill go check to see if I can start it.
Would the coolant temp sensor give set off a CEL?
Old 12-24-2004   #15
x1genx
x1genx's Avatar
Drives: 90 1g awd
Send a message via AIM to x1genx
Ok the coolant temp sensor will give off a CEL and it should be 21. I have also had the same problem. If you have a logger or pulse checker for the terminal check for the cel once you get the car running like CRAIG said before.Make sure on the CTS that the wiring is not clipped due to age and wear etc.etc...and then go from there.
x1genx is offline   Reply With Quote
Old 12-25-2004   #16
jd1828
There is no CEL so Im not sure if that could be the problem.
Old 12-25-2004   #17
jd1828
I got it started today. I pulled the plugs and they were covered in gas and they were bosch platinum, yuck. So I put in a old set of bpr6es i had laying around. It started right up. The only problem is that it stumbles under full boost and 3k+ rpm. Does a 2g take the same plugs as a 1g because thats where i got those from?
Old 12-25-2004   #18
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
I would say get some new plugs. I don't know if they are the same.
Old 12-26-2004   #19
Plug wires can cause the stuttering.
Old 12-26-2004   #20
TheBlizzard
Drives: Too Many
Plugs are the same. Make sure they are gapped correctly. I am assuming you pulled them out of a 2G Turbo right? But I would just get some new ones regardless. And like Peter said, plug wires will cause boost related stuttering as well. If that doesn't fix it, I would rule out boost leaks as well.
CRAIG
