Old 02-25-2005   #1
AZT
Cleaning talon rim lip. (pic enclosed)
http://memimage.cardomain.net/member...9_207_full.jpg
On the rims in the above pic, there is a silver lip that is around the edge. on mine, Its looking really grimy nad has buildup on it that looks like dirt and soap or almost like mold. i was wondering how to get it off there. Its not a part of the rim, its sometihing on it. does anyone have an idea on how to clean it?
AZT is offline   Reply With Quote
Old 02-25-2005   #2
Re: Cleaning talon rim lip. (pic enclosed)
Its called corroded aluminum. You have to sand or grind it smooth and then polish it and put a clear coat on it. Or just paint the lip.
Old 03-05-2005   #3
INTRIGUED
insert witty title here
INTRIGUED's Avatar
Drives: VW Gti
Use a dremel (sp?) tool. I am sure that would take it right off.
Old 03-05-2005   #4
I would scotchbrite it, then polish it with polishing compound.
Old 03-06-2005   #5
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
We used a rag dipped in brake fluid to get the big stuff off and then used a scotch-brite pad to get the smaller stuff smoothed out. Then polished it. Then clearcoated the lip. Takes some time but is well worth it in the end. We did this on a buddy of mines rims on his Fiero the night before a car show.
Just make sure you wear gloves when working with the brake fluid and don't get any on any other painted part that you don't want to have to repaint.
Old 03-07-2005   #6
DSMPARTSGURU
Keeper of the lost toys!
Drives: 1977 pinto,1994 farm truck, 04 4-door mustang
Send a message via MSN to DSMPARTSGURU
LOOKS interesting, never thought to use brake fluid as a stripper...
CHRIS
Wayzata Nissan
DSMPARTSGURU is offline   Reply With Quote
Old 03-07-2005   #7
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
It cuts thru the clearcoat that is on the lip so you don't have to sand thru it so much. That way you only have to sand the corrosion.
Like I said, you don't want to get the fluid on anything else that you don't want to strip the paint off of.
Old 03-08-2005   #8
DSMPARTSGURU
poor man paint stripper?
hmmmm
CHRIS
Wayzata Nissan
Old 03-08-2005   #9
Kougar
Drives: 06 RSX
Aircraft stripper would work well in taking the clearcoat off also, but that stuff is REALLY nasty if ya get it on something you didn't plan on.
