Old 07-29-2005   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
help me with my high EGTs....
I have a problem.
My car sucks, I know all dsmers say this but honestly i cant figure out this problem. First off I own a 92 laser AWD 6/4 bolt. with basic bolts on, 3" turboback ported 2g o2 housing and manifold. rebuilt motor. rewired fuel pump. stock injectors. stock sidemount.
My problem is that my car tends to get in upwards of 1500-1600 degrees whall at WOT at 14 PSI. My logger o2 volts show me its at .91 which is still pretty rich? I have no knock, and my timing advance is at 19-21 degrees. my question is, what is causing these way to hot temps? any other infomation you guys need just ask. I have no tuning tool though...
-Colin
Old 07-29-2005   #2
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: help me with my high EGTs....
If you don't have a way to richen it up then you are pretty much screwed. I wouldn't trust the 02 volt reading that you are getting anyway, they are not very accurate.
Old 07-29-2005   #3
N/M
Last edited by Jakey; 07-29-2005 at 09:05 AM.. Reason: I need to learn how to read.
Old 07-29-2005   #4
blageo23
AWD4G64
blageo23's Avatar
Originally Posted by Jakey
Why is he running so rich? Does re-wiring the fuel pump with a remaining stock fuel system make that big of a difference to cause a rich condition without any sort of fuel management?
By reading this I swear he is running lean not rich. But anyways I have this same problem. And my AC fan is melting. It sucks!
Old 07-29-2005   #5
I'd swap out your o2 sensor & see if you get a different reading with a different one.
On second thought, buy a wideband setup & see what you're really doing. Your stock o2 sensor is not very accurate & may be giving you false reading.
You're still running the stock turbo, I assume? Where in your rpm band at WOT are you getting these high readings?
Old 07-29-2005   #6
.91 is not rich. And EGTs are also innaccurate and vary from EGT sensor location to EGT sensor/gauge model. 1650+ is also the dangerous zone for EGTs, 1550 would be a pretty good EGT temp. EGTs aren't very good for tuning though, they respond more to retarded timing than being lean. They can be used for individual cylinder trim tuning, if you have 4 of them, then they actually become useful.
Old 07-29-2005   #7
Wow, my reading skills obviously weren't with me earlier. N/M the above shit.
Old 07-29-2005   #8
91nbtsi
Send a message via AIM to 91nbtsi Send a message via MSN to 91nbtsi
Yeah, I hated my EGT gauge, so I took it out. All I ran was the wideband, fuel pressure gauge, and boost gauge. Oh, and knock control on the AEM. Otherwise, I found all other gauges/sensors worthless.
10.806@133.15--1991 Talon
91nbtsi is offline   Reply With Quote
