Old 09-26-2005   #1
rk4g63
Burp!
Send a message via Yahoo to rk4g63
650 cc RC injectors fit, oil pres & temp gauge hookup locations
I wasn't sure if this qualified as a tech thread or not - but I put it in here anyway.
I'm getting a set of RC 650 cc injectors and I'm not sure if they'll drop into my car.
The numbers on the injectors are as follows:
The one closest to the top is 0924 and the other is 0100768.
I have a 94 Talon Tsi AWD with a stock 7 bolt. It has a big 16g and stock fuel rail and stock injectors.
Question 1: Will these injectors drop straight into my car?
Question 2: Where will an oil pressure gauge and an oil temp gauge hook up? Both are electronic (brand VDO) and have senders. Probably 14 gage wiring.
Thanks!
rk4g63 is offline   Reply With Quote
Old 09-26-2005   #2
rk4g63
Burp!
Re: 650 cc RC injectors fit, oil pres & temp gauge hookup locations
Additional info I got from the RCENG website:
Sizes available in Saturated (high resistance) 550, 650, and 750 cc/min AND
Peak and Hold (low resistance) 550, 750, and 1000 cc/min
Which is better for my setup?
Old 09-26-2005   #3
You need low resistance injectors. High resistance injectors won't work, unless you plan on doing some rewiring.
Old 09-27-2005   #4
rk4g63
Burp!
Thanks!
