Old 08-25-2006   #1
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Weird idle
In the morning when i first start up my car it will idle at about 900 rpms. Which i feel is about right. after i have been driving my car around for a little while it will start idling at 2000 rpms or sometimes even greater. Anyone know what this problem is.
Elementality158 is offline   Reply With Quote
Old 08-25-2006   #2
Re: Weird idle
Does the idle jump around or is it always, approximately 900 rpm and then later on always, approximately 2000 rpm?
Old 08-25-2006   #3
Re: Weird idle
Maybe check ignition timing?
Old 08-26-2006   #4
awd_owns_you
Send a message via AIM to awd_owns_you
Re: Weird idle
I tried to track down an idle issue for a long time, I ended up having to loosen one of the cables comming out of the box on the firewall just alittle, the right cable if I remember right. But have you tried checking the simple things like the isc/faiv and vac leaks?
awd_owns_you is offline   Reply With Quote
Old 08-26-2006   #5
Elementality158
Re: Weird idle
Its at about 900 when i first start it, then after driving, it stays around 2000. Timing was just done a few days ago. vac is good. Ill take a look at the cables tomorrow. But i think its more in the computer, because its not like it sticks or anything. I tried lifting the pedal and it didnt seem to help any.
Old 08-31-2006   #6
Elementality158
Re: Weird idle
I figured it out. Just a sticky cable. Just a little Knock Er Loose on it and its all better.
