Old 12-22-2005   #1
DSMkel
Send a message via AIM to DSMkel Send a message via MSN to DSMkel
What do I have here?
Picked this turbo up from a friend of mine. The turbo supposidly came off a MK3 Supra. I was told it is a Garret 57 trim TO4E .57 cold side .63 hot side. I'm gonna be honest by saying I don't really know much about turbos, and this is why I'm askin. Any info is much appreciated.
http://www.logicrealms.com/4images/d...ture_016_2.jpg
http://www.logicrealms.com/4images/d...ture_017_2.jpg
http://www.logicrealms.com/4images/d...ture_018_2.jpg
http://www.logicrealms.com/4images/d...icture_019.jpg
http://www.logicrealms.com/4images/d...ture_020_2.jpg
http://www.logicrealms.com/4images/d...ture_021_3.jpg
Type-Arrrrgh KILLA
"If it's never broke you're not driving it hard enough"
DSMkel is offline   Reply With Quote
Old 12-22-2005   #2
Onefast99gsx
Re: What do I have here?
Looks like a 57 trim but then again a 57 looks alot like a 50. Both are a .60 A/R. You'll probably have to take the compressor cover off and measure the inducer/exducer size of the wheel. The compressor wheel sure looks burnt or discolored for some reason. None of mine have ever looked like that. I don't know though.
Some of the pros on here might be able to tell the turbo size just by the shape of the compressor wheel.
Old 12-23-2005   #3
Nah, measure the wheels to know for sure. Pictures don't mean much.
Old 12-23-2005   #4
Well, you know it is a T04E cover. There could be many possible wheels in it, the most common being 54, 57, 50, and 60 trim (going from smallest wheel to largest flow). 54 and 57 trim are cheaper than the rest, so I don't see why it wouldn't be the 57 trim. All are pretty similar in flow.
Old 12-23-2005   #5
You could measure both the wheels to identify those and look for the A/R markings on housings to figure out those part. The setup you described is extremely common and likely.
Old 12-23-2005   #6
DSMkel
Thanx for the info everybody.
I've done some research and have come to the conclusion that tracking all the parts down needed to bolt this particular turbo onto my car will be a pain and or waste of time and money.
Type-Arrrrgh KILLA
Old 12-26-2005   #7
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Really? What would you need? As I see it, you would need a manifold, downpipe, maybe an adjustment in charge piping, and some oil adapters to flow oil thru it. Anthing i'm not thinking of here?
