Old 02-11-2006   #1
mitfastgsx05
Clutch Question?
Last night i got home into my driveway and i pushed down my clutch and it stook to the floor i got it off and pushed it down and it start to make a whining noice every time i push it down. It was also making this smell. When the car was running it wouldnt go in or out of the gear it was in but if i shut it off and push in the clutch it goes into gear. im not sure what the deal is or could be so as much help is appreciated. well i asked a friend and he said it could my pressure plate and thats all i got so far.
clutch is a act 2600 i believe
thanks alot
mitfastgsx05 is offline   Reply With Quote
Old 02-11-2006   #2
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: Clutch Question?
Sounds to me like your clutch master cyclinder is bad. Change that. Go under the dash and see if it is leaking where it enters the car.
BTW, you need more info when posting in the tech section. You didn't even say what year car, type, engine, mods ect. Read the rule buddy.
Old 02-11-2006   #3
Outlaw1
Resident Redneck
Outlaw1's Avatar
Open the hood and look around. Is there even any fluid left in the clutch master? Did you open the hood to try and find where the smell is coming from? I know it sounds like I'm being a dick but you can't fix a car if you don't even start to try.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 02-11-2006   #4
GVR-4579
I am thinking Throw out bearing nut im not too sure from your description, i just think if its whining when you step on the clutch then it could be the throwout bearing.
My 2c
Old 02-11-2006   #5
Are you problems similar to this?
http://dsmstyle.com/forums/showthread.php?t=10287
Old 02-11-2006   #6
blageo23
AWD4G64
blageo23's Avatar
Your clutch pedal doesnt make a difference if the car is off. You can put it into any gear you want. Try pushing the clutch in and opening the bleeder and see if any air comes out or if there is even pressure on the fluid and check to see if the slave moves. Also check the fluid level. Aslo Isnt there sometimes a problem with a 2600 and an old/warn out slave cylender(the rod not being long enough to push the fork far enough to push in the clutch).
Old 02-11-2006   #7
mitfastgsx05
sorry i have a 97 gsx with 6bolt, act 2600, boost controler, safc 2, shep racing tranny, internals, full 3 inch exhaust, some more but i dont think they matter but if they do im sorry.
