Old 03-01-2006   #1
x-pride
x-pride's Avatar
2G engine swapped to 6bolt
I have a 2g...What do I need to do inorder to swapped over a 6bolt...i.e...switch knock sensors...ignition coils...etc..etc..
Old 03-01-2006   #2
Re: 2G engine swapped to 6bolt
You can use your 2G coils. You will need a 6-bolt flywheel. You need to get a 1G CAS and do some simple wiring. And then pray that the random misfire problem doesn't cause happen.
Old 03-01-2006   #3
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
so the motor mounts fit right onto the 2g (GSX) body?
ლ(ಠ益ಠლ)
Old 03-02-2006   #4
Use the 2g mounts on the 6-bolt.
Old 03-01-2006   #5
blageo23
AWD4G64
blageo23's Avatar
http://www.magnusmotorsports.com/article_1g2g.htm
Old 03-17-2006   #6
acidrumz
An definite internet research would yield you the correct response. Or you can save the headache and hire a reputable shop to worry for you.
There are a couple shops in or around the metro area with sustainable amount of knowledge.
gluck.
yy
