Old 05-16-2006   #1
SLOW_V
3 inch inlet down pipe
I have a 2g gsx and have a good deal on a 3 inch down pipe (all the way) that eliminates the cat. Will I need a 3 inch o2 size to use it? Or could I use the stock o2 housing for now?
SLOW_V is offline   Reply With Quote
Old 05-17-2006   #2
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: 3 inch inlet down pipe
... You should be able to use the stock o2 housing. You will most likely boost creep. Having a custom o2 housing or o2 eliminator makes life easier. Just make sure you have a decent operating boost gage if you are going to run 3 inch on a stock setup.
- Josh L.P.
Old 05-19-2006   #3
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
How would running a straight 3'' exhaust cause boost creep? I'm wondering this because my exhaust is just that. (This is an honest question)
pics or gtfo
Old 05-19-2006   #4
Craig answered that question in your boost creep thread.
Old 05-19-2006   #5
tim
tim's Avatar
I would say that you wont be able to use it. I actually ran into the same problem when I bought Nash's exhaust. The distance between the studs on a stock o2 housing is about 3" so you probably wont be able to get the nuts on. The flange matches up and everything you just cant put the nuts on. You would be better off getting a 3" tubular.
Old 05-17-2006   #6
Does the stock O2 housing flange match the flange on the downpipe?
