Old 06-22-2006   #1
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
Send a message via AIM to joesushi
Turbo selection question.
We have a 2.4L with 8.8 pistons crower L2 cams+springs
I need suggestions on what turbo to get.
This car needs to spool quickly. It's going to be a daily driver, BUT i would also like something that can get 400+ AWHP. So maybe a turbo rated to 500HP?
Another thing is what type of manifold to get? we have a stock 1G one now, so its gotta go.
We also have to decide on which way to swing here: mitsu? T3/T4? One of those SBR Evo3 manifolds look pretty cool.
Imagine that you are starting from square one, which way should i go? And also, we dont want to get really pricy: maybe a 50 trim or a 60 trim. Those should spool prettty quickly on a 2.4. What do you think? I'm pretty sure that we dont need ball bearing and thats way expensive too.
Thanks
out-running the velocichoppa! in my dsm.
joesushi is offline   Reply With Quote
Old 06-22-2006   #2
Re: Turbo selection question.
use.....more...ellipses...please........
Old 06-22-2006   #3
What do you consider fast spooling? My 50trim hits 18psi at around 4k. I love the turbo, but really don't think I'll ever want anything laggier.
Old 06-22-2006   #4
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
We(collectively) are used to 14b/16g series of turbos, we like how the respond to RPMs.
We also understand that we are going to have some lag if we want high HP, we just want to have the least culture shock of lag as possible....if you get my drift
drift....what a dirty word after FF3
Old 06-22-2006   #5
95talonracer
95talonracer's Avatar
I have the Big evo III 16g ported and polished. I like it alot and its very affordable. It also is rated at or around 400 hp.
Old 06-22-2006   #6
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
I fully understand the affordability and the performance possibilities of the evo3.
Thanks for your vote, but if nobody can suggest anything we are thinking 50, 54, or 57 trim so far
Old 06-22-2006   #7
x-pride
x-pride's Avatar
50 trim is a good place to start.
Old 06-22-2006   #8
Shotgun!
Totenritt
Shotgun!'s Avatar
With a 8.8 2.4L you are going to spool things very quick. CVD's 2.3 with a 50 trim felt like a 14b. He could pass in 5th gear. I vote you look into the turbo sale that is going on at PTE.
SCM61
The other thing I have to say is that you are talking about comp wheels like they matter in "spool". The truth is; not so much. You should be asking about what turbine housing to use. Anything with a T3 .63 turbine housing will spool very fast.
Old 06-22-2006   #9
400whp on pump gas? Race gas? Pump/alky?
I say go big or go home, something with a 61mm compressor on it, SCM61 or similar. 50-trim will spool very very nice for ya with the 2.4 though.
Old 06-23-2006   #10
At-Least-It's-An-Evo
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
74mm turbo. No other way.
Old 06-23-2006   #11
slowbubblecar
slowbubblecar's Avatar
I have a SBR G60 60 trim that spools in the 4000 range that I might be willing to sell. I also have a SBR cast manifold as well.
Old 06-23-2006   #12
Thor06
11 Seconds to Freedom
Thor06's Avatar
I've heard some "bad" things about 54 and 57 trims. Not really bad things, just that 50 or 60 trims are better choices. I would say go for an SBR 50 trim or slowbubblecar's 60 trim. Either way you will be making some decent power. I too have a extra manifold, its an unported uncracked 2g manifold. If you want it, shoot me a PM.
Old 06-23-2006   #13
Toss a 50 trim on it and you will be happy. I have the SCM61 on my car. It is still very streetable, but not a comparison to a 16g.
Old 06-23-2006   #14
400awhp on race or pump gas? It sounds like you are looking for something that will have some throttle response, so something like a 50-trim or GT30R would work. But it would be hard to make 400awhp without something in the 61mm size range on pump gas. The ball-bearing versions of the 50-trim aren't too expensive. The Mitsu exhaust housing versions will spool faster, but give up some HP. The Mitsu housings work fairly good on the 50-trim, they get a bit too small and restrictive when you start getting into 61mm turbos.
Old 06-23-2006   #15
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
The car will be running on 92/93 octane
How about one of these turbos? http://www.slowboyracing.com/shop.php?sid=&cat=1267
this intercooling kit http://www.slowboyracing.com/more.php?id=154&
And this manifold http://www.slowboyracing.com/more.php?id=1343&
With a T3, what exhaust do i need to get? is there an O2 housing adapter so we can use a kit exhaust? I'm new with T3 stuff, used to mitsu exhaust housings and such.
Old 06-24-2006   #16
http://www.dsmstyle.com/forums/showthread.php?t=11891
Old 06-23-2006   #17
If you want a full t3/t4 setup, I have that brand new setup that is on the white race car at my place. It will be off this weekend as the car is being parted out this weekend.
Old 06-24-2006   #18
stormbird
Some buddies and I just bolted up my FP3052 tonight.
That's what I'd get if I were you.
stormbird is offline   Reply With Quote
Old 06-24-2006   #19
FP3052 all the way, you won't regret it.
Old 06-24-2006   #20
slowbubblecar
The turbo, manifold, FMIC and 02 housing setup on my 90 I have listed for sale I could sell.
