Old 10-01-2006   #1
SLOW_V
Tansfer case wedged into oil pan
I bought a 94awd talon manual 5spd. The motor siezed from previous owner. I was pulling the motor this weekend when I ran into a tough situation and is stopping me from getting the motor out. The tranfer case somehow wedged itself against the oil pan. There was a hole in the oil pan created from the transfer case against it. I suspect this is why the motor went south. Anyways, how can I remove the transfer case and left cv shaft without messing them up? Any suggestions will help.
I also tried jacking up the motor to see if it will create some space to move transfer out. It did not work. Any other suggestion.
SLOW_V is offline   Reply With Quote
Old 10-01-2006   #2
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Tansfer case wedged into oil pan
Did you pull the tranny yet cause I believe you gotta drop the tranny case and pull pass CV shaft and intermediate shaft before tranny and engine can come out.
Kinda confused by what you mean messing them up???
Old 10-01-2006   #3
SLOW_V
There are not enought clearence to removed the transfer. The oil pan is directly next to it and wedged. It is not supposed to be like that.
I don't want to jack the motor too much and have the transfer and cv shaft still in the tranny. This might messed up the seal or other things. The left cv shaft can't come out until the transfer is removed.
Old 10-01-2006   #4
Is the transfer case partially dislodged? Is there an abnormal shape to the oil pan there? It should come right out, unless something inside the engine pushed the pan out. At this point it might be time to bend the oil pan in with a hammer. You could always get another oil pan.
Old 10-01-2006   #5
SLOW_V
No, not even dislodged,completely wedged. I will try to bang the heck out of the oil pan.
Old 10-01-2006   #6
You've got nothing to loose at this point. Hammer away.
Old 10-02-2006   #7
Either your xfer case is no longer bolted to your tranny or your oil pan moved. There should be a decent amount of clearance if everything is bolted together properly.
Old 10-02-2006   #8
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I suppose a busted rod could have punched the oil pan out, BFH time!
Jim
Old 10-02-2006   #9
x-pride
x-pride's Avatar
Jim
Could be because I thought he was an idoit and than I looked. I was mind boggled on how this could of happened. The Oil pan had expanded near the transfer case and there was no way of getting the transfer case off. The only solution was to smash the oil pan.
Old 10-02-2006   #10
HKSenilyks
Send a message via AIM to HKSenilyks
Why not unbolt the driver side cross member and unbolt and remove the oil pan, then removing the x-case. Or is that not going to work either?
Thaught
HKSenilyks is offline   Reply With Quote
Old 10-02-2006   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Did you go over and help him???
Old 10-02-2006   #12
SLOW_V
The dude never came over when I was home. He came when I was out ,peek under the car and called it a day. He was telling it was my shit and I should be able to handle it myself. Next time when he needs his brakes to be bleeded.I will go over and tell him it is his shit!
Nick you need to come over and give me a hand! You seem to know what you are doing!
Old 10-03-2006   #13
acidrumz
is this car that black 94 talon awd?
Old 10-02-2006   #14
Transfer case blocks some of the oil pan bolts.
Old 10-02-2006   #15
SLOW_V
I finally got the shit apart. A friend came over and he looked at it, went to unbolted the tie rod, balljoint and bang the shit out the left cv shaft. It finally pop out. The next thing is to pull out the motor with the tranfer case on it.
Old 10-03-2006   #16
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
What needs to get done Oh and You need to help me drop that 1g motor into my Colt just gotta get an ECU and 1g wiring harness. Ill check this when I get home might be able to help Sunday
Old 10-03-2006   #17
SLOW_V
Sunday will work. You will love to install the 350 small block V8 in the talon. Nice and easy swapped.
