Old 09-04-2006   #1
How to make a Quick 14B Car?
Anyone wanna just quick slap a list of some stuff I'd need to maybe run low 13's on a 14B (Just things to add power). Could I get to that goal with..., 3" exhaust, 1G ported cast exhaust parts, stock sidemount, race gas, boost controller, fuel pump?
Oh yeah It's a 92 awd 5 spd 6/4LSD w/ buschur 3"dp,tp,cb, shep stage 3, 2600w/6puck
Old 09-04-2006   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: How to make a Quick 14B Car?
+SAFC, dyno time, C16, seat time.
Old 09-04-2006   #3
You could hit a low 13 with that no problem. I ran a 13.6 with boost controller, pump gas, 2.5" hacked cat-back and ghetto UICP. Full weight on snow tires.
SAFC and UICP should get you well into the 12's.
Old 09-04-2006   #4
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Just make sure you have the fuel to backup the boost
pics or gtfo
Old 09-04-2006   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
I ran 12.99 @ 103 on my old AWD with an open downpipe, UICP, and some c16.
If you had safc 550's and a pump you could run that or better and not worry about blowing up.
Old 09-04-2006   #6
Yea, go for it! Exhaust, fuel pump, 550's, and an afc. 2G mas for good measure, crank up the boost to about 25, drop the tire pressure in the front to about 17psi, and maybe about 13-15psi in the rear, and then get some good clean launches. Shit, you could run high 12's on that setup if you can drive well enough!
Old 09-04-2006   #7
My girlfriend wents high 12s many times and 108mph with the 14B, air filter, 2.5" turboback exhaust, mbc, fuel pump, a homemade upper i/c pipe that didn't seem to help and race gas. Cher went something like 12.6 with similar basic mods. Someone else on here went low 12s with the 14B.
A 2G MAS, 550s, SAFC, FMIC, etc would be nice for tuning it.
Old 09-04-2006   #8
Are you guys serious? Wow, if this is true then maybe i should think about keeping my B16G with pretty much the above mods, plus dsmlink, but minus the FMIC/pipes (i am stock IC system right now).
Sleepy good to hear that you are getting back in the game!!
Old 09-04-2006   #9
13.4@98mph.
1.70x 60' 3bolt FTW!! .
Mods:
s-afc, 3" 02 back exhaust, 2g mas in a 1g airbox setup, homebrewed intake pipe, aeromotive fpr, act 2600, walbro 255hp. Stock injectors, motor, etc... This was back in 2003?
Another mod, 90psi compression in cylinder #1, 135+ on the other 3.
15psi, 92 octane. Full weight.
Once I broke the 3 bolt the next pass at the track, I tossed in a 4 bolt and turned up the boost to 18psi, much faster.
I think nash then took this car put on his fmic, 660's, heads w/cams and 20g and went 11.6?
It really isn't that hard to get a strong 14b car into the low 13's, high 12's.
Old 09-04-2006   #10
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Kevin, make it light. I guarantee if a 14b on race gas/stock motor was put into my white car it would go high 11s easy at about 113-114 no problem.
'04 Honda Ricer: stock
Old 09-05-2006   #11
Alright, so I need to at least get a pump (duh). I'll probably buy a FMIC, but I need to wait until I get my bill from Shep haha.
Old 09-05-2006   #12
94AWDTSi
Dang kevin, my car is pretty much crap then! I'll probably drop by this weekend if your not doing anything!
94AWDTSi is offline   Reply With Quote
Old 09-05-2006   #13
Can't you get a MAF-T setup to do something similar to what a s-afc does?
Old 09-05-2006   #14
MaseWindu
Send a message via AIM to MaseWindu
I had similar mods, fuel pump for sure, and ran a bunch of 13.4 passes full weight and full exaust.
MaseWindu is offline   Reply With Quote
Old 09-06-2006   #15
I have a MAFT actually, and a 91 EPROM. just get some injectors, and maybe get a RACE GAS chip burnt? And then just run 15ish psi on pump? Eh maybe I should just get DSMLink. Can someone tell me if you can save different "maps" on DSMLink?
Old 09-06-2006   #16
I'm thinking boost creep is gonna be EL GAY, I'm kinda in the market for an external gate o2 housing, but I can't find any.
Old 09-06-2006   #17
Just get the turbo ported. Much easier and cheaper.
Old 09-06-2006   #18
Hey what would you use to port it, carbide bits, grinding stones, sanding rolls? Could you use Carbide bits with a dremel? Or would something like that be better suited to an air-powered grinder?
Old 09-07-2006   #19
Gravy
Who's this guy?
After just finishing a porting job myself, GET A DAMN CARBIDE BIT!!!! I did a stock 1g mani and wish i hadn't been cheap. I got the carbide bit on the last night of porting. Cut the time in half, easy. Use the carbide to take out larger pieces of the metal and get the areas ground down, then use a stone to smoth them out. Follow up with some sand paper to get it nice and smooth and your all set.
Old 09-06-2006   #20
Or bolt on a o2 housing, problem solved.
