Old 10-23-2006   #1
tjg
Check engine light
Ok, my check engine light is on but everytime i hook up my obd2 it says error. Does anybody have any ideas on why it wouldnt let me pull a code.
tjg is offline   Reply With Quote
Old 10-23-2006   #2
Re: Check engine light
Have you tried a different scanner?
Old 10-23-2006   #3
tjg
No, I havnt yet but the scanner works on my other cars, I thought maybe the scanner was out of juice or sumthen. Does anybody know of a main relay that has to do with the ecu getting power.
Old 10-23-2006   #4
blageo23
AWD4G64
blageo23's Avatar
If the fuse to your ECU isnt working then your car wouldnt start and there would be no check engine light. Try a different scanner.
Old 10-24-2006   #5
tjg
I have it hott wired.
Old 10-24-2006   #6
Shane55113
Now 20% less Racist
Shane55113's Avatar
pop open your ecu box and check if the caps are leaking, when they leak tons of stupid things happen, its a 15 min diagnosis and an easy enough fix
Old 10-24-2006   #7
Meaning you have a hardwire feeding your ECU constant power? I think you just solved your own problem.
Old 10-25-2006   #8
tjg
No i dont have a hott wire feeding it constant power! I just bypassed some stuff.
Old 10-25-2006   #9
tjg
I was thinking that would be the problem but it cant be.
