Old 09-12-2006   #1
Gsxedyou
Send a message via AIM to Gsxedyou
boost controller
Anyone have good instructions for a boost controller installation?
Gsxedyou is offline   Reply With Quote
Old 09-12-2006   #2
Re: boost controller
check http://www.vfaq.org
The ball end goes towards your boost source, the spring end goes towards your wastegate actuator.
Old 09-12-2006   #3
Assuming you are using a standard ball/spring manual boost controller, the bottom hose goes to the nipple on your turbo/turbo outlet and the side hose goes to your wastegate. Make the lines as short as possible to help eliminate boost-spike and speed up response time. Remember to zip-tie all connections!
Old 09-12-2006   #4
Yup, except when using my buddies turboXS one. I hooked it up backwards because I was used to all MBC's hooking up with the boost source on the bottom nipple, and the WG going to the one pointing sideways. But Austin's TurboXS one was completely backwards.
Old 09-12-2006   #5
Yeah short and simple.
I actually maxed my current boost controller out. It wont go in any further. but i have the forge UNOS one. i have to find the other spring for it, it comes with two of them, one for low boost (under 25psi) and one for high boost.
Old 09-14-2006   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
geez! just disconnect your wastegate
Style's automotive engineer
Old 09-14-2006   #7
Hoffer00
Cantankerous Tank Champion! Fight Man Champion! Go Johnny Go Champion!
Send a message via Yahoo to Hoffer00
It depends what you have. If it is a TurboXS Dual stage I can help you out with detailed instructions.
Hoffer00 is offline   Reply With Quote
Old 09-14-2006   #8
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Zip ties. That would be smart. I'm waiting for mine to fall into my fan at some point...
Old 09-16-2006   #9
The turboXS high performance, with a ball and spring and a bleader all in one is what we have had the most luck with as far as MBC's goes. Just fallow the directions with the MBC and you should be fine.
Old 09-16-2006   #10
The reason I like the FORGE over the TurboXS, is because the TurboXS you need to use an allan to adjust. The forge you just turn the cap. And it also clicks when you turn it. So if you decided to bump the boost up to have fun, you can remember you turned it 8 clicks, and then just turn it 8 clicks back when you're done, and you're exactly back where you used to be.
Plus you can get it in the ever so inconspicuous BLACK color, so you don't have a bright blue turboxs controller looking all goofy.
Old 09-16-2006   #11
Gravy
Who's this guy?
Now here's a good question for everyone. Is there any way to tell which is the ball side without any instructions? I"m going to be coming by one shortly and it won't come with any directions. I don't feel like pushing osmething up inside the niple to figure out if that's the ball end.
Old 09-16-2006   #12
Turbo xs high performance boost controllers are silver.
I have one in my stealth and love it. Consistant boost is a good thing to have.
Old 09-16-2006   #13
But still requires an Alan to adjust right? I don't like having to carry around an allan wrench to change my boost. I like my knob that has clicking intervals, and is anodized black.
http://www.forgemotorsport.co.uk/con...product=FMUNOS
And I purchased the Forge Unos from LSE! And I'm willing to bet it was a good bit cheaper then the Turboxs High Performance one.
Old 10-31-2006   #14
tim
tim's Avatar
My JoeP(the very first style) needs an allen wrench to adjust boost, plus the wrench to loosen the jamb nut. It works ok though, if you really wanted you could use different bolts and have a thumb nut instead of the super long allen set screw thing.
I am pretty sure this post will mean nothing to anybody. That is ok though, I am drunk and kind have an idea what is going on.
Old 10-31-2006   #15
I had the same one
Old 10-31-2006   #16
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I love my Joe P., still use it with zero issues to this day. I do like the new Joe P. inline boost controllers that are anodized in black, stealthy. http://www.joepmbc.com/images/MBC%20pics/blacksmall.jpg
Also Elite and DB Performance sell a boost controller in various colors for $35.
I have always ended up routing my boost controller into the intake one way or another. I seem to have weird boost issues if I rout it right off the turbo, just my experiences.
Old 10-31-2006   #17
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Mine is blue. It's the one I bought from QPR a couple years back. I think it was Allen who sold it too me and it came off of Mike's car. And it's currently busted. Doesnt hold boost at all. (bad spring?)
The only thing I like about using the allen wrench is that no one else can mess with your boost if anyone else is screwing around with the engine bay, unless they have that certain sized allen wrench. But I like the knob style better. It's easier to use, IMO.
You can always take apart the MBC to see which side is the spring or ball side. It's not very hard, from what I've seen and used. Or try the trial-and-error way .
Old 10-31-2006   #18
Originally Posted by 1slowdsm View Post
It's the one I bought from QPR a couple years back. It came off of Mike's car. And it's currently busted. Doesnt hold boost at all. (bad spring?)
Sorry, but that's funny. It must have been his super secret boost controller that he engineered from unobtainium.
Old 10-31-2006   #19
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
turboDSM is offline   Reply With Quote
Old 09-16-2006   #20
Yeah we sell the Forge units as well.
I've used the Turbo xs, so thats what I recommend.
