01-03-2007
Mazda-ing
Drives: 2013 Mazdaspeed3
My car keeps dying.
1990 Mistubishi Galant LS
Well my car has been running great until today. Nothing gradual or anything, just BAM.. started this.
So today I went to the store before work and as I was leaving I started my car and then it just died. The clock was re-set but it started right back up. Then after work I ran to Kohls and it did the same thing, but this time, it kept dying if I took my foot off the gas. The lights would dim as well, but brighten if my foot was on the gas. Basically, as long as I kept my foot on the gas, everything was normal. And every time it died it would start right back up, however it would die right away if I didn't IMMEDIATLY have my foot on the gas. Now every time it dies, the clock isn't being reset, but the check engine light comes on and so does the brake light.
Oh and as a side note... the check engine light had been on since I bought the car, so Steve tried to hook it up to the pocket logger but it wasn't showing a code so he turned it off. A day or so later it came back on. As soon as the car started dying it turned off while running but comes back on when the RPM's drop and it starts to die.
Any ideas? So far I've heard Alternator, TPS, and auto control motor. Please help!
01-03-2007
Re: My car keeps dying.
Get your alternator and battery tested at Checker or Autozone.
Drives: Cars
id check those out first also.. sounds like it just has a bad battery
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
01-03-2007
Mazda-ing
Alright will do. My dad also told me to put some fuel injector cleaner in it and drive it around a bit and see if it helps, so I'm going to do that and see if it makes any sort of difference. I'll report back when I'm done.
01-03-2007
Mazda-ing
Thanks I'll have Nick do it!
01-03-2007
Wanker
Drives: 95 M3
I always recomend checking your main power and ground wires as well. They can corrode and have a similar effect to a bad alternator or battery. (road salt sucks)
01-03-2007
Go to checker have them test the alternator and battery and they can also look up what the check engine light is coming up for. Ask them if they will do that or you can borrow the diagnostic tool with a downpayment and then get a refund, I have done this.
01-03-2007
Mazda-ing
Actually their diagnostic tools don't work for my car, since its a '90. I think those only work for eith 92+ or 95+
01-03-2007
Mazda-ing
Well thats interesting...
I took my dad's advice and added a bottle of Sea Foam Fuel Injector Cleaner and it runs like normal again. Actually I take that back. When I stop it will drop to 500 rpm's but then it brings them back up to normal. Very strange. My boyfriend thinks there's probably something a little more in depth than that but so far its running so I'm just going to leave it be for now since I can't afford to fix anything else, haha.
But in the process of fixing this problem, I also realized I have an oil leak some place. I was nearly out of oil.
01-04-2007
I hate everyone
If the clock reset, that means it lost power at some point in time. Get your battery and alternator checked out, clean your battery terminals, check alternator fuses and lil stuff like that..... If it all checks out, then your car could possibly be the anti-christ and I would perform an excorsism immediatley
01-04-2007
I already tried pulling the codes, it didn't come up with any. Sounds like an alternator or alternator belt. I thought I replaced the battery, I can't remember.
01-04-2007
So you tried to pull the codes, when there was a check engine light, and nothing showed up? That's odd.
01-04-2007
Mazda-ing
Well... Last night the problem was fixed with a simple bottle of Sea Foam. After sitting all night I wonder how it will do. I'm about to go run some errands so I'll see how it does. If it's still acting up, I'll pull the battery and have it tested, but I'd rather not have to pull the alternator if I don't have to. But if the battery is good I will just have to pull the alt.
01-04-2007
I highly doubt that seafoam fixed the actual problem... Sounds like your battery terminals could be corroded and dirty if the radio reset. Its as if someone disconnected the battery all together. Then if you clean the terminals and you still have problems, look in the alternator.
01-04-2007
The alternator is tested right on your car as is the battery. Your lover should know this.
Sea-Foam did not fix your electrical problem.
SeaFoam didn't do shit. As long as the car starts with ease every time, it's probably not the battery. bad terminals (loose or fucked up otherwise) are generally going to not allow a solid connection for start up every time. My money is on the Alternator. Something could be loose, and just tightend up enough to allow the car to run better. Chance are it could be related to the idle as well. Could be a combo to. But the fact is if you alt is going out every now and then, it's probably draining the shit out the battery to keep the car running.
roll up to Autozone, tell you lover to sit his ass in the car and take car of the shit yoruself. Walk in, flash some boobies, get it done promptly. You'll have 2-3 guys looking it over for ya. LOL Unless they are gay, then get the lover out the car and put him to work.
01-04-2007
Mazda-ing
Well it runs fine now? I don't know what the problem is/was but its not doing anything abnormal now. So until it fully breaks, I'm not fixing it, because I can't afford it. But I'll keep all this in mind.
01-04-2007
Wanker
Drives: 95 M3
If your alternator isn't functioning properly and you're running off the battery at times you will kill the battery fast. Why waste the money on a new battery when testing is free?
01-04-2007
Yeah no shit, getting your alternator and battery tested is free, no reason not to get it done. If your alternator is faulty, it will kill your battery real quick and cost you even more $$$.
I agree. With short trips you can run off the battery for a couple days. To me it sounds like your alternator is taking a shit. Car batteries are not meant to be charged and discharged multiple times. If your alternator is junk and you already had a close call your battery could fail too.
I would make sure your alternator is working under load, if Steve replaced the batt before you bought it I doubt it is the problem, although it is possible.
Your symptoms do not seem to be drivability related, they seem electrical and should be found out for sure before you are left stranded.
