Old 01-16-2007   #1
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Fuel pressure lines
Dont feel like typing much so im gonna go half assed. Car takes forever to start in the cold. I replaced the coolant temp sensor. Im not sure if the wires are still good in the car, they look old and im not sure if its getting a good connection. But when i turn over the car. The fuel pressure regulator gauge jumps up and down from 0 to 30 and when i let off on the key it drops back down to 0. Im pretty sure that it should stay pressurized after i let off on the key. Any one have any answers to my questions?
Thanks
Elementality158 is offline   Reply With Quote
Old 01-16-2007   #2
x-pride
x-pride's Avatar
Re: Fuel pressure lines
My guage hangs there a little but than goes back to zero once the key is out of the ignition. How is your charging system?
Old 01-16-2007   #3
Elementality158
Charging system? Not sure what you mean by that.
Old 01-16-2007   #4
Elementality158
Fuel pump is brand new. i think it might be one of the lines running from the top of the pump assembly. Or i was thinking fuel filter might be bad. Not sure though. Ill take a look at the MPI relay and the ignition transistor. I might just go pick up a new relay.
Old 01-16-2007   #5
Thanks
I don't feel like typing much, so I'll give a half assed answer.
It sounds like you have a fuel pressure issue.
Honestly, I would check your fuel pump, mpi relay, and if it isn't a fuel related issue, the ignition transistor can cause a slow start issue.
Old 01-16-2007   #6
Did this happen after the pump install? It sounds like a fuel pressure issue, bad pump/wiring, bad o-ring from pump to fuel sending unit, fuel leak, bad regulator. How about the FP gauge it self, is that broken?
Old 01-16-2007   #7
Fuel filter would not cause that issue, it would be a consistant lack of fuel pressure.
O-ring is a good possibility as well, good call John.
Old 01-16-2007   #8
Elementality158
It happened after i did an engine swap. Maybe the O rings on the injectors? Wouldnt i see fuel shooting from one? Maybe i should switch to a stock fpr.
Old 01-16-2007   #9
Is the fuel pressure gauge electric or one just screwed into the FPR?
Old 01-16-2007   #10
Elementality158
screwed into the fpr. maybe i should take it off and put new teflon tape on it? or just not go by that?
Old 01-16-2007   #11
No, if it's not leaking externally, it's fine. You should always teflon tape threads, but that's a different thread. You're obviously losing pressure real fast which shouldn't happen. I'd look for a leaking injector or a bad check valve on your fuel pump. Except for an external leak, nothing else should cause immediate fuel pressure loss.
Old 01-16-2007   #12
Elementality158
It is a brand new fuel pump but maybe something is wrong with it, maybe i should go back to the stock one. This one im using is a 190. When i let off the key the fuel pump keeps running for a second, like it should. But its hard to hear it while im turning it over, maybe its not pumping enough while im turning it over. Ill switch back to stock real quick and see what happens.
Old 01-16-2007   #13
Did you lubricate the O-Ring on the fuel pump before you installed it? That is a fairly common spot for people to lose pressure at. I'd suggest looking at that and replacing that O-ring, they aren't that much money anyways.
Old 01-16-2007   #14
I agree, probably the fuel pump install.
Old 01-17-2007   #15
Elementality158
Alright ill give that a try. Thanks guys.
Old 01-22-2007   #16
Elementality158
What does the ignition transistor look like. I have something here from my pile 'o parts. It says Power TR Unit. Im guessing thats it.
