02-22-2007
alternator squeal.?
is this a sign that my alternator is going out.. ?
91 GSX..
squeals.. a lot when cold.. and even now that it is warmer it does squeal at lower RPM..
any answer would be great..
tsua
02-22-2007
Re: alternator squeal.?
Tighten the belt.
02-22-2007
Drives: 90mitsu
^^^^ ditto!!!!
Maybe also check your Alternator fluid in case it's low.
02-22-2007
Assuming the car is a 1G, the alternator fluid passes through the flamidation valve between the reservoir and the alternator. If there is something causing a flow restriction in the flamidation valve, the alternator could be getting starved of fluid.
02-22-2007
Drives: 90mitsu
fluid????
Wanker
Drives: 95 M3
Originally Posted by johnson
fluid????
   You really are behind on the technology, aren't you? Get with the program man!
02-22-2007
Alternator fluid? What is that........
Usually I just spray some wd-40 on it or else tighten it.
02-22-2007
Yup, just like how you need to check the water in your battery. You need to check the alternator too.
02-23-2007
Drives: 90mitsu
i have a 1g alternator in front of me and i dont see any fluid.....
I have 2 1g, and a colt one, all in front of me. They are all at the perfect level.
02-23-2007
yeah, i had a problem once, i drop PS fluid all over my alt. and it got in it. Then i had to drain it and refill it.
02-23-2007
It's a good thing you drained it. The seal quality in the 1G alternator coolant passages is quite poor so power steering fluid would definitely cause some damage.
02-23-2007
Drives: 90mitsu
only if i knew what i was lookin for??? thats why i have the pros rebuild my alt...
Probubly a good thing
02-23-2007
Your alternator squeals? It means it wants out... You are hurting it. Your ECU probably has a virus and I bet your cams arent camming right.
Better check the Variable Transister Accumulator Kintetisizer while you are in the area.
On a side note, if you cut the belt, it wont squeal anymore.
02-23-2007
Ya but cutting the belt is just a band-aid. You need to fix the root cause, which is probably your fluid level.
02-23-2007
I hate everyone
HAHA, you've gotta be kidding me....
02-23-2007
Drives: Cars
those damn alternators are always leaking!!
i believe i just became dumber...
p.s. dont forget to check the flux capacitor... always givin me troubles..
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
02-23-2007
Click,Click,BOOM!!!
Funny, Funny, Funny!!! Had me saying WTF, Ahhh yes the fluid how could I be so Stupid..
