Old 04-05-2007   #1
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Dual Bosches?
Anyone run dual bosch pumps? I see twin walbro pumps, but I'd be interested to see dual bosch setups.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 04-05-2007   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: Dual Bosches?
link to said bosch pump please
Old 04-05-2007   #3
Swifty1638
Swifty1638's Avatar
Re: Dual Bosches?
http://www.jayracing.com/images/Bosc...lbro_255HP.JPG
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 04-05-2007   #4
Speedfreak
Drives: four tires
Re: Dual Bosches?
Not sure why you'd want two of these. If done properly, two Walbro's will supply enough fuel for 99% of the dsm'rs out there. And you can buy two Walbro's for less then the price of one Bosch. The Bosch pumps are also quite a bit larger then the Walbro's.. making it very hard to fit in a tank if you go that route.
I would follow these rules, first shot, 1 Walbro. If you want one pump and need more, then buy a Bosch. If you need more then one Bosch, then buy two Walbro's. If you need more then two Walbros, then go with two Bosch's or with three Walbro's for even more capability.
Old 04-05-2007   #5
rst95eclipse
Re: Dual Bosches?
It sounds like you're running a cell. With ethanol and some large injectors, it will probably need two. It's really nice that they're external pumps and they can survive the "negative effects" with running corn. I do not have this setup, but I will be using it - whenever that will be.
Old 04-05-2007   #6
Re: Dual Bosches?
I will be running a single -044 this year on a fuel cell and all SS lines. I'll be running E85 and 1600's (weak point will be the SCM61). There is a great thread on NABR about fuel pumps. If a single -044 won't do it for you, then use a 255 as a feeder pump.
Old 04-05-2007   #7
Re: Dual Bosches?
I'm running twin Walbros. Nice and clean install and it's actually quieter than my old single Walbro used to be. Since that will support 1000 hp, I'm not sure why you'd go bigger than that. Plus the 044's are inline pumps, so it'd be a lot easier to use any in-tank to feed it, which is a popular setup as well.
Old 04-05-2007   #8
Re: Dual Bosches?
On 1g's, people have gotten to fit the 044's in-tank. When I run out of fuel with my 255hp, that is what I plan on doing. If for some god awful reason I manage to max that out, like they said above, a 255 in-tank feeding an external 044 has been showing to flow a ton.
