Old 04-03-2007   #1
gsxer
wastegate question...
Ok I have a 20g with a t3 flange and Im about to get a t3 manifold but its set up for 44mm wastegate...Is that too big of a wastegate?
thanks
gsxer is offline   Reply With Quote
Old 04-03-2007   #2
mdost03
Sonic Champion!
Drives: VA STI
Re: wastegate question...
How much boost do you plan on running?
Old 04-03-2007   #3
Yeah, that is huge for a 20g. Why not just get a mitsu flanged 20g and bolt it right up?
Old 04-03-2007   #4
you cant have too much wastegate.
Old 04-03-2007   #5
b00stcreep21
I hate everyone
b00stcreep21's Avatar
80mm wastegate ftw?
Yeah, the 44mm might be a bit overkill
Old 04-03-2007   #6
gsxer
Ok, so what do you guys recommend 38mm, 40mm I got the 20g from my cuzin and he had it flanged for t3 and he sold it to me for 75 bucks so I couldnt refuse that offer.
Old 04-03-2007   #7
I'd just use a Tial 38mm. It'd work perfect for you. But if you already have the 44mm, and it fits fine, then I don't see why couldn't just run it as long as the spring in it isn't for a higher pressure then you plan on running.
Old 04-04-2007   #8
44mm is a little big
I use 38mm's on my pte 50 and pte 61
Old 04-04-2007   #9
What is defined as a little big?
I don't recall ever seeing a discussion on this board about external wastegate sizing so this could turn into an excellent discussion.
Old 04-04-2007   #10
b00stcreep21
I hate everyone
Or it could turn into something like the multiple intercooler threads we have....
Old 04-04-2007   #11
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
It willl be fine. The end.
'04 Honda Ricer: stock
Old 04-04-2007   #12
Speedfreak
Drives: four tires
Correct. If the extra $ for a 44 doesn't bother you, then it will work perfectly.
Old 04-05-2007   #13
badinblack
badinblack's Avatar
Drives: 96 talon, 2.4L & 3582r
too big is better than too small, and latter if you get a rediculus turbo you wont have to get another wastgate, just a new spring.
badinblack is offline   Reply With Quote
Old 04-05-2007   #14
gsxer
so 44mm is ok then huh...
Old 04-05-2007   #15
Speedfreak
Drives: four tires
um yes
Old 04-05-2007   #16
mdost03
Sonic Champion!
Drives: VA STI
Make sure the spring inside of it is the right one for the amount of boost you want to run.
Old 04-05-2007   #17
I correct my previous statement, here's an excellent thread:
http://www.dsmstyle.com/forums/showt...rnal+wastegate
Old 04-05-2007   #18
gsxer
thanks jakey
Old 05-02-2007   #19
Tman1gtsi
38 works for alot of things, I have a tial 38 that I don't think ill ever go bigger
Tman1gtsi is offline   Reply With Quote
