Old 04-28-2007   #1
v8klla
v8klla's Avatar
479whp ~ 427 ft/lbs on OEM Longblock!
MAP '93 Eagle Talon (Alex Wolner)
OEM 6 Bolt Shortblock
OEM Intake Manifold
OEM ECU
2G MAS
Crower 414 Cams
SC61 Turbo
SAFCII
28 psi on E85 fuel
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 04-28-2007   #2
Re: 479whp ~ 427 ft/lbs on OEM Longblock!
MMM CORN GAS.
Good work guys.
Old 04-28-2007   #3
plymouthPSi
Send a message via AIM to plymouthPSi
Oh, this is my daily driver also!
plymouthPSi is offline   Reply With Quote
Old 04-28-2007   #4
4Las90
4Las90's Avatar
Drives: Evo 8 RS
Send a message via AIM to 4Las90 Send a message via MSN to 4Las90
Yeah but that doesn't mean it runs every day...
4Las90 is offline   Reply With Quote
Old 04-28-2007   #5
Very nice! Was this car running the same tune today at LSE? For reference, on their Dyno Dynamics it put down ~405whp. That's some nice powa!!!
Old 04-28-2007   #6
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
What all did you do to make it run E85? Great numbers!
Tyler Aherns
-USN-
Old 04-29-2007   #7
dumb_ricer
Hates Everything
Drives: Neon
Send a message via AIM to dumb_ricer
The boost was the same as it was when we made 480, but he street tuned it some right before the dyno as it was breaking up under boost. Didn't seem to break up too badly on the dyno on the 2nd pull, and it put down pretty decent power, so we have nothing to complain about.
E85 "mods"
1000cc injectors (I think)
Walbro fuel pump
Stock feed and return lines
Aftermarket AFPR
AFC-2 for tuning
2g MAS (duh)
We will probably turn the boost up and go for 525ish wheel hp and then take it to the track. At least that is what *I* want to do (not my car)!
Its got everything BUT a built motor, so why not blow this one up.......right? Right!
420A > LS1 > All Else
I > All else
dumb_ricer is offline   Reply With Quote
Old 04-29-2007   #8
Swifty1638
Swifty1638's Avatar
Meh, if Mike Rizzotti can make 584ish on a stock motor, there's no reason you guys can't make the standard up higher.
-A. Swift
Old 04-29-2007   #9
dumb_ricer
Hates Everything
Drives: Neon
-A. Swift
Was he on stock ECU and tuning with an SAFC? C16?
E85 and running the stock timing map will fuck things up QUICKLY if there is any detonation.
Were not worried about the rods, but the 6bolt pistons will crack a ringland with pretty much ANY detonation at this power level it seems.
I'm sure we'll have it up on the dyno making more power shortly........But I think we want to get it to the track and try to put down a time before it blows up and Alex has to fork over money for a built motor! Even at this power level, I think a 128ish mph trap speed isn't out of the question. I want to see 130, but it's Alex's car.
I > All else
Old 04-29-2007   #10
http://www.rizzottiracing.com/
Old 04-29-2007   #11
v8klla
v8klla's Avatar
Originally Posted by Jakey View Post
Yeah slight difference in mods I would say lol. I don't know if Alex wants to go that crazy without a built shortblock, but hey we can give it a shot!
Chris
P: 763-545-3800
Old 04-29-2007   #12
Didn't Nash make 531 whp on a 2g piston/1g rod bottom end? His head was lightly ported, but had smaller cams and an SCM61. His was on C-16, 2g mas and SAFC also. I would say that is the number to shoot for
Old 04-29-2007   #13
It should be good. My wifes 1G puts down 384awhp on the DD with a factory mitsu longblock with the metal Mistu headgasket, HKS 272s, 50-trim@26psi, 1G MAS. The turbo is just about shot on it, so I want to goto an SC61 and wasn't too worried about the motor taking it. Nash's motor went through hell and held up for a while.
Old 04-29-2007   #14
dumb_ricer
Hates Everything
Drives: Neon
You two got married?
Once again I'm not worried about the 1g rods. I am worried about the pistons. 2g pistons are known to hold up to substantially more abuse than the thin land 6bolt pistons. I have seen countless burnt/cracked ringlands on OE 6bolt motors. I must say that Nash's motor did take a SHIT TON of abuse though. I've never thought a motor was going to blow up so much in my entire life than when I heard he was running 40lbs.
We'll see what happens and what Alex wants to do. I think if we hit 510-520whp and take it to the track, we might like the results! There will be no C16! E98 will probably max out his injectors, so we are stuck with E85. Hopefully the Walbro 255HP can keep up.
I > All else
Old 04-29-2007   #15
Yea, we got married last fall.
Why no C16? Just because of cost?
Yea, it's always a risk pushing a car that far. You never know if you got the factory freak motor also or the one they built right after drinking a 6-pack at lunch.
Old 04-30-2007   #16
You're thinking of the big three automakers. I don't think they allow unions in the Japanese owned American plants.
Old 04-30-2007   #17
PSI2HI
Send a message via AIM to PSI2HI
What kind of airflow #'s are you seeing? Surpised the 2G MAS isn't freaking out yet.
I ran a stock block setup as well for years making 500+whp never had any problems.
PSI2HI is offline   Reply With Quote
Old 04-30-2007   #18
dumb_ricer
Hates Everything
Drives: Neon
No idea on air flow numbers.
I am equally suprised the 2g MAS isn't getting outflowed yet.
I > All else
Old 04-29-2007   #19
dumb_ricer
Hates Everything
Drives: Neon
Because C16 is too easy!
The way I look at it is it is a low compression motor running a fuel that "cools" compared to gasoline, and makes more power than 110 octane, there is no need for C16. That and it cost's a boatload.
I don't see why we can't make a trackable 525whp. And then tune it back to like 450 for daily driving.
I > All else
Old 04-30-2007   #20
Mike still didn't blow up his motor at 585 whp, he just pulled it to be on the safe side. He's very careful about everything he does to his car including tuning, so you can be sure it lasted that way due to probably never seeing detonation. I'm sure 600 whp+ on a stock block is feasible with careful tuning.
