Old 05-06-2007   #1
Spline-drive lug keys are sh*t!!
Ok, I made the mistake of using an impact wrench with my first one, and it stripped. I took the wheels off the evo today (no impact guns!) and when I went to torque down the last 3 lugs on the last wheel this happened. Does anyone know where to get either:
a) a decent spline-drive lug key or
b) some other lugs w/ a key that doesn't suck BALLS
Old 05-06-2007   #2
Re: Spline-drive lug keys are sh*t!!
Just to note: I used this key to torque down a few lugs after the original one stripped, and then used it to remove the wheels once and re-install wheels once. ONCE! GAHHH!!!
Old 05-06-2007   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Just done use an impact and it will be just fine. Take a lug or the key to a parts store and see if they have anything that matches.
If you have no luck and need to buy new lugs, beat the key back into shape and have it welded so you can get the old lugs off.
My spline drive lugs/key work just fine. No problems after 3 years.
Good luck man!
Originally Posted by shoutbox
Old 05-06-2007   #4
I have a spare one, but it started to split just like this one on the same lug that this one split on. Could it be a bad lug nut? Or am I just a lugnut? You seriously used an impact gun w/ one of these w/ no beakage/strippage? How many times did you R&R w/ the same key?
Old 05-06-2007   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I've used an impact a few times with it, but I dont like tq'ing lug nuts down with impacts... Tq wrench works just as well and I know what they are tq'd to. I usually use the impact just to take them off. I've also seen impacts snap the studs off when over tightened. Thats just another reason why I dont use one.
Old 05-06-2007   #6
http://www.gorilla-auto.com/products...=249&sfID2=254
I used these for years on multiple sets of wheels and they were great. If you don't like this style, there are plenty of others available from Gorilla.
Old 05-06-2007   #7
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Go to a discount tire store, they always have a bunch layin around
Old 05-06-2007   #8
^^ +1
Old 05-06-2007   #9
sleepy2lazy
sleepy2lazy's Avatar
Check out discount tire store, but if they don't have it, you might be out of luck. Their key remover tool, pending on how the lugs sit on your rims, will not work properly. It can damage your wheel. There is also another tool or something they use, but the dude couldn't remember when I went there.
The second option, See if you still have the registration code and all other information when you bought your special lug / key. If you do, just give the company a call.
My sisters were messin with my stuff and lost my key. =(
Old 05-06-2007   #10
b00stcreep21
I hate everyone
If I'm not mistaken, they're just spline drive lugs, not a "keyed style" lug that requires a special key. Right Chris?
Old 05-07-2007   #11
polishmafia
Smells like cat poop
polishmafia's Avatar
x2. they dont look like a special key, just a spline key.
i have one for my car exactly like the one you broke. if you need to borrow it let me know.
Old 05-07-2007   #12
Yea, it's not that I can't find a replacement, just that I've now broken one key every time I go to mount the wheels back on the car. Just stupid!
Old 05-07-2007   #13
Try not to use all that massive strength you have!
Old 05-07-2007   #14
x-pride
x-pride's Avatar
How much are you torquing? If you are breaking these things you might want to make sure everything is OK. I only torque my wheels to 100 ftlb
Old 05-07-2007   #15
I think the problem is nothing more than poor quality generic products.
