Old 05-08-2007   #1
driftn1g
intake hard pipe
im trying to replace my stock plastic intake tube with a hard pipe. i noticed that there is a difference in size to where it bolts to the turbo and to the intake box or maf.. what size cupplings would i need on both sides and where is a good hard pipe with that kind of bend?
Old 05-08-2007   #2
Re: intake hard pipe
What size of turbo do you have? Stock is 2.25".
Old 05-08-2007   #3
driftn1g
ya i have stock.
so i will need a 2.25" from the turbo, to im guessing 3.0 or 3.5 to the maf..
still looking for a pipe thats bent like that
Old 05-08-2007   #4
driftn1g
if i remember right, theres two hoses that run off that intake tube into the engine.. will getting an intake pipe with one nipple and plumb a T fitting on it work??
http://cgi.ebay.com/ebaymotors/Mitsu...25822683QQrdZ1
Old 05-08-2007   #5
you can just cut off the elbow and put in a 45* 2.25" hard pipe and use the rest of the stock rubber one. I think there is a VFAQ on it.
Old 05-08-2007   #6
Dejon makes some pretty decent intake pipes for good prices.
Old 05-09-2007   #7
driftn1g
dejon as in the website or a member? i found the write up but its with plastic pvs pipe.. i learned that those two hoses can be vented to the atmosphere or plugged with fuel filters
Old 05-09-2007   #8
www.dejontool.com
Don't use PVC under your hood, if you insist on going the Home Depot route (which you shouldn't) use ABS plastic instead.
Old 05-09-2007   #9
driftn1g
thanks!
