Old 06-20-2007   #1
Onefast99gsx
Unhappy Xfer case bolt stripped !!
Hey guys... just when things were moving along ok, I went to bolt the xfer case onto the tranny last night and I began pulling threads on one of the xfer case bolts. There are 5 bolts that mount it to the tranny(3 long & 2 shorter ones). This happens to be the top shorter one that's right next to that little rubber vent thing. It bolts in to where there is resistance but never stops to where a torque will develop. I didn't overtighten nor did I cross thread it. Don't know what the heck....
I know I should heli coil it but the proper way to do it would be to remove the tranny and i DON'T want to do that right now. Besides, with the a/c compressor in there, I don't think I can get enough room with a drill. Perhaps over the winter. I already tried a little bit longer bolt and it helped some but it still didn't take care of the issue.
Do you think it would be alright if a guy coated the threads completely in loctite red 272 and screwed it in to where it seems the tightest and called it a day???
Thanks guys..
Old 06-20-2007   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Xfer case bolt stripped !!
I would think it would be alright if it's only temporary, but then again even the slightest loose bolt causes vibration and such. The point where the bolt is doesn't seem like it would be as critical as the others, but that's just an educated guess.
Old 06-20-2007   #3
Onefast99gsx
Well I don't plan on take it down the track at all a single time this year if that makes any difference. The bolt turns in on the threads. It's not like I can just take the bolt and push it in without turning. It seems like it gets fairly close to the point where a bolt would stop turning when its snug, except this bolt keeps turning. Stripped... I'd like to just take some red loctite and douse the threads, screw it in to where it seems as tight as it will get and be done with it for now.
Old 06-20-2007   #4
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Well, I guess as long as you don't launch it, just leave the bolt out. 4 out of 5 isn't too shabby. I wouldn't normally recommend this, but It seems that you know it's wrong. Fix it over the winter. Till then, take it easy.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 06-20-2007   #5
b00stcreep21
I hate everyone
b00stcreep21's Avatar
I'd suggest taking the a/c compressor off and see if you can get a drill in there. Otherwise, a tranny job really isn't that bad
Old 06-21-2007   #6
Just try and make room. Don't go without one of the 5 transfer case bolts. they are there for a reason lol! Heli-coil it, and be done!
Old 06-21-2007   #7
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Mehhhh, I had 3 out of 5 on my 600hp car, 20+ launches. It never fell off.
'04 Honda Ricer: stock
Old 06-21-2007   #8
Onefast99gsx
Funny....
Well I ordered a whole helicoil kit. Nobody had it locally so I ordered it from Grainger. It will be here by 10am tomorrow. My plan is disconnect the a/c pump, tie it up with a coat hanger and go to work. Sucks I gotta disconnected it. Those 2 bottom a/c bolts are a pain in the ass being that you can't get a ratchet on them.... I haven't had a winter yet that I wasn't working on a dsm so I figured if I can get this done now, maybe I can have the winter off by not having to take tranny out.
I will snap some pics. I'm really pushing to start this thing up sat or sun if I don't end up having to order something else.
Old 06-22-2007   #9
Shane55113
Now 20% less Racist
Shane55113's Avatar
i'm rocking 4 x-fer case bolts. When me and swift did my clutch the last bolt was GONE, we could not find it. My car runs great.
Old 06-22-2007   #10
Onefast99gsx
Thanks Shane55113 for the post...
Update: Had the day off today so I went to the Grainger store 35 minutes away and picked up the kit (not Cheap $85.00). Comes with everything though and numerous lengths of M12 thread inserts. Unfortunately this thread repair will have to wait till winter. The a/c compressor is not what's in the way, it's the frame. Any drill with a big enough size of chuck to handle this bit size is just too big & long of a drill. I hate 1/2 assing stuff but this will have to be 1/2 assed until November. Tomorrow morning she's getting locktite red 272. I'm gonna crank it till the point where I feel it won't tighten anymore without make the threads worse and subconsiously forget about it until winter when i pull the tranny. At least I have the kit for when the time comes.
