01-03-2004
01-03-2004
Ummm, the boss, pardon? :bounce: :bounce:
What type of head will you be using Mike, 1G or 2G?
01-03-2004
BOSS refers to a cast in block of metal or surface that allows for drilling and tapping.
1G head.
01-03-2004
A 2.4 I presume? If so the 6-bolt block that comes from doesn't have a boss on the number 2 cylinder like the two liters have. There's a boss closer to cylinder number one you could use, but I'm interested to hear what porn-star Marco comes up with.
-edit- I see it is a 2.4 since it uses the individual main caps instead of the regular girdles. Very nice indeed. Is that the long rod or regular rod version?
01-03-2004
Another thing, did he put in oil squirters? I noticed the pistons aren't coated.
I want one. :bowdown"
01-03-2004
wow, pretty. who are u stealing from to get money to buy shit like that?
01-03-2004
2.4L stage 4 (lightened rotating assembly)
Long Rod
No oil squirters
1G head Stage 3 port work/1mm oversize Ferrea valves/ double springs
Marco said the pistons will be fine without the coating or squirters.
01-03-2004
Hard work, my boy, hard work.
01-03-2004
Lightened rotating assembly? The crank looks rebalanced but stock. Is the crank pulley cut down or something?
01-03-2004
There are some bosses on the front side of the block that could be used, but I'm concerned about heat damage to the sensor from the exhaust/manifold heat.
01-03-2004
500 grams are removed from the rods and pistons
01-04-2004
Originally posted by 1ViciousGSX@Jan 3 2004, 10:41 PM
No oil squirters
What reasoning other than insanity is behind this?
(Looking for a serious answer...)
Originally Posted by Tachyon
01-04-2004
Is this the same as your block?
01-04-2004
Originally posted by Matt D.+Jan 3 2004, 11:03 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Matt D. @ Jan 3 2004, 11:03 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-1ViciousGSX@Jan 3 2004, 10:41 PM
No oil squirters
(Looking for a serious answer...) [/b][/quote]
One less problem to worry about, but the pistons will get pretty hot and probably cause detonation earlier. I thought most people were putting a heat coating on instead. I'd trust Marco though, he's the 2.4 king.
01-04-2004
How are the oil squirters something to worry about?
01-04-2004
It looks the same except for the hole thats tapped next to the 2 middle ribs at the center near the deck surface. The pic you put up has it, mine doesn't. Even if mine had that extra hole driiled and tapped, it wouldn't allow the knock sensor to mount flush.
01-04-2004
Here's another pic of what I'm talking about.
01-04-2004
It is believed that a faulty or leaking squirter could contribute to the "crankwalking" problems with these engine. I do know that John Shepherd's engine has them blocked off as well as Marco's with no problems.
01-04-2004
Nice nice nice.......
01-04-2004
Did you get that pic from a site dedicated to 2.4L issues?
