Old 08-27-2007   #1
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Dynoed today.
I went to LSE for the 3 pulls for $40 today. Im very happy with what my car put down. It made a little more power then I was exspecting.
We had a few problems With the TPS sensor on my Q45 Throttlebody but I got it working before the last pull.
Thanks alot john for letting me make a few extra pulls and for the help. I think you forgot to change the Name on the printout though.
Pulls were on E-85 28 psi 2.0 SCM-61 DSMLINK
Video http://videos.streetfire.net/video/3...970150b572.htm
11.35 @ 120mph
Old 08-27-2007   #2
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
Re: Dynoed today.
NICE!!!! Now thats some sweet power, good job.
Old 08-27-2007   #3
Re: Dynoed today.
Wow, that is some power. I have a similar setup in daily driver 1G and it put down 436awhp. Even with the drivetrain loss for FWD vs AWD, you probably still have 20-30whp on my car. Do you have a chart with boost on it? What RPM did it hit 28psi? I still need to do a sheetmetal intake, hopefully that will pick up around 20awhp and get me into your power range.
Old 08-27-2007   #4
Re: Dynoed today.
Awesome man!
Old 08-27-2007   #5
carltalon
carltalon's Avatar
Re: Dynoed today.
I only have the one chart. John might know when It hit 28. It spiked over 30 right away then settled in to the upper twentys. Im running an internal wastgate so the boost wasn't to stable at those levels.
11.35 @ 120mph
Old 08-27-2007   #6
Speedfreak
Drives: four tires
Re: Dynoed today.
What size fuel injectors?
Old 08-27-2007   #7
jeffescortlx
Re: Dynoed today.
850's.
Awsome power, and still running a stock turbo mani and internal gate. Sweet.
Ford Escort 1.9 SOHC 2150lbs
212.2whp 262.6tq
jeffescortlx is offline   Reply With Quote
Old 08-27-2007   #8
carltalon
carltalon's Avatar
Re: Dynoed today.
FIC 850CC with 50 PSI base fuel pressure.
Added video link to first post.
11.35 @ 120mph
Old 08-27-2007   #9
Onefast99gsx
Re: Dynoed today.
Dam, nice numbers! What were your air flow numbers on dsmlink?
Old 08-27-2007   #10
carltalon
carltalon's Avatar
Re: Dynoed today.
I think on the last pull they were in the lower 50's. I posted A LOG on the link forum from one of the first pulls. I think was around 45 pounds per min
11.35 @ 120mph
Old 08-27-2007   #11
Re: Dynoed today.
Nice Carl!!! Finally some numbers out of that beast! Very good ones at that, congratulations!
Old 08-27-2007   #12
Re: Dynoed today.
Nice job Carl! I am glad to see my old Laser coming back better than ever! I want to get in there for that special too. I have about the same setup too, but with the stock intake mani like shane. I hope to be around 460 awhp like I was last year on 111. Did you get the HRC DP from JoeM on here?
Old 08-27-2007   #13
carltalon
carltalon's Avatar
Re: Dynoed today.
Yup And hid Eprom ecu. Wernt they both yours at one time?
11.35 @ 120mph
Old 08-27-2007   #14
Re: Dynoed today.
Yep! Lots of that car came from me I'll have to talk to you more sometime. I have a few questions.
Old 08-27-2007   #15
Re: Dynoed today.
Well I could be an ass, but 3 clean pulls is what I normaly try to give you guys, its a little harder with your bald DR's and maxing your injectors so I can not use my easy injector back probe for Tach pick up, and spinning tires is something I am not used to also. I will print off a new graph with your name and info on there, I forgot, and if you want a boost vs A/F I can do that, swing by when ever to get them.
Old 08-27-2007   #16
carltalon
carltalon's Avatar
Re: Dynoed today.
Thanks again John. No big deal on the printout. But I might need it for some sceptics.
11.35 @ 120mph
Old 08-27-2007   #17
Re: Dynoed today.
45lbs? At what PSI was that? My 50 trim clocks in about 41lbs on Link at 25psi.
Old 08-27-2007   #18
carltalon
carltalon's Avatar
Re: Dynoed today.
That was at around 25psi Im not shure how accurarate it is through the MAFT
11.35 @ 120mph
Old 08-27-2007   #19
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: Dynoed today.
I would say not accurate at all.
I would guess my car maybe makes around 400HP maybe more on a Dyno Dynamics and it flows 54lbs per minute on the Link. Mine is an unhacked 2g MAF at 27psi with the PTE 3561.
Old 08-27-2007   #20
Re: Dynoed today.
I have the new print outs here, I need one for the book anyways.
