Old 09-18-2007   #1
driftn1g
EGR check engine
Ok i get a EGR check engine light on all the time.. is this bad to run the car like this?? and where is this sensor at?
Old 09-19-2007   #2
iceminion
iceminion's Avatar
Re: EGR check engine
Is the EGR system different on 94's? every DSM (90-92) I have worked on I have always disabled the EGR systems and blocked it off with a plate. No CEL.
If your EGR system is broken, you may want to consider blocking it off with a plate.
I do not believe that any harm can come from your car with a stuck open EGR system, although a car with a stuck closed EGR system is what is desirable.
building a 3000GT AWD Turbo.
Old 09-20-2007   #3
Well you'd have a massive boost leak if you have a failed egr system.
Old 09-19-2007   #4
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
I have an extra EGR valve if you need it.
The EGR valve is located on the passenger side of the intake manifold near the battery tray. Check the vacuum lines running to and from it.
Old 09-19-2007   #5
driftn1g
thank, i got a block off plate
Old 09-20-2007   #6
One a 1g the actual solonoid is mounted on the intake manifold and is acuated via vacumm.
The solonoid is located on the firewall.
Old 09-20-2007   #7
driftn1g
wait.. that makes sence, cuz it use to go on and off, mostly stay off.. now its stuck on after basically not caring and running my car with knock... now that leak is fixed but its still on.. i can clear it with the logger
Old 09-20-2007   #8
xveganxcowboyx
Wanker
Drives: 95 M3
If you blocked it off you might as well yank the solenoid and vacuum lines. Clean up that engine bay.
Old 09-21-2007   #9
Damn California spec 94 ECUs.
