Old 10-20-2007   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
BOV question
So I haven't found much info on this topic or maybe I don't know how to search for this topic...
So I am planning Stage 3 upgrade for my car (it is how I name the time when I do something for my car) and it is going to get a bigger turbo, about a 50 trim or 20g (but that discussion is for another thread), bigger injectors, and other fun stuff...
I was wondering if my BOV is going to be venting enough air?
Right now I have a Blitz DD BOV and from what I understand it only holds 18psi untill I get a hard spring for it. It came with the intercooler and hard pipes that were custom made. I really don't know too much about this BOV other then from what I have read. It sound like people purchase it more for the sound then anything else...
If I shouldn't use this BOV what would people recomend?
But will this flow enough air so compression surge doesn't happen. Last thing I want when I buy a bigger turbo is to damage the thing with improper parts...
Old 10-20-2007   #2
Re: BOV question
I would probably try it and see what happens. If it doesn't work then you can upgrade to a Greddy, Tial or HKS. If you like the whistle, buy the HKS. I bought one a long time ago when there weren't many choices and kind of like the whistle. It really makes people jump When I go to a bigger turbo I will put a Tial on also.
Old 10-21-2007   #3
Andrew7dg
Andrew7dg's Avatar
Re: BOV question
Ok when I do upgrade what will be a sign that I would need a bigger BOV?
I guess I will buy the spring and see what happens.
I am going to be the first to say that I don't really care about sound. This one makes A LOT of air noise but that really doesn't matter. I just want to make sure that nothing bad happens to the turbo.
Old 10-21-2007   #4
Re: BOV question
http://www.tialmedia.com/documents/w3_tial_bov50_sp.pdf
Old 10-21-2007   #5
mdost03
Sonic Champion!
Drives: VA STI
Re: BOV question
Tial is what I recommend. HKS gets too annoying after a while IMO. The new GReddy RS is ok, but I preferred the older Type-S "sound-wise".
Old 10-21-2007   #6
Re: BOV question
I'm replacing my stock 1g with a Tial.
Old 10-21-2007   #7
Re: BOV question
Tial. Hang onto your stock 1G one and crush it until you you need to run a ton of boost though, more bang/buck!
Old 10-21-2007   #8
Andrew7dg
Andrew7dg's Avatar
Re: BOV question
The Blitz DD has a different flange so I can't put the 1G back on, otherwise I would have and sold the Blitz for $$ I really don't know which one is better, the Blitz or the stock 1g
It sound like Tial is the way to go from vote. Probably I will sell the Blitz and the 1g and go with Tial flange and make a new pipe so I can also eliminate the GM MAF (switching to different management system)
http://i217.photobucket.com/albums/c...g?t=1192998685
You can see in this picture how that system works and how close it is to the thermostat housing.
Edit:more I look and compare BOV the more I am liking Tial... Probably that will be choice. It doesn't even sound loud which might be a nice change!
