Old 10-30-2007   #1
blageo23
AWD4G64
blageo23's Avatar
Fuel Rail Idea, Do You Like?
Im not going to take credit for this because I saw one for sale on ebay but need to know if it makes sense.
Here is the basic idea. Our cars have a problem with cylinder #1 not getting enough fuel(less then the others). So I thought this would work but Im not an expert like some of you guys.
Take your stock fuel rail and drill a whole in the center of the fuel rail(inbetween injectors 2 and 3) and you make that where the return line goes. Then you make both sides of your fuel rail inlets. So have fuel inlet on both sides of the rail and the return in the middle.
Does that make any sense to you guys? would this give you optimal fuel or would the fuel get all F'd up in the middle of the rail?
Old 10-30-2007   #2
Re: Fuel Rail Idea, Do You Like?
#2 is actually the cylinder that runs the leanest generally.
Old 10-30-2007   #3
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Drives: 1992 Eagle Talon TSi AWD
I thought that was due to air distribution, not fuel?
TwoTalons is offline   Reply With Quote
Old 10-30-2007   #4
From how I understand it is because fuel pressure is at its lowest at injector #2 since the fuel enters at #4 and hits a "wall" at #1.
Old 10-30-2007   #5
When did DSMers turn into 3Sers?
Old 10-30-2007   #6
If there is infact a lean condition in a certain cylinder i would not attribute it to fuel distribution in the rail. Its an incompressible fluid moving at a relatively slow rate.
Old 10-30-2007   #7
Wait, where is all this bad info coming from? Our cars have no problem with #1 not getting enough fuel. There is something like .00000000000001psi of pressure drop across a 1' fuel rail, I am might be exaggerating, someone with the math skills could figure it out, but it is inconsiquencial. Variance in flow from one injector to another from dirty or just bad fuel injectors is much more likely. We have been able to track down a bad fuel injector on the dyno a couple times that caused a car to detonate too easy, but they were flowing so much less that you could tell in plug coloring.
Old 10-30-2007   #8
Good to know. Back in my days of hardcore DSM researching on 'Talk it was the general consensus that #2 ran leanest b/c of fuel pressure drop across the rail.
What is the proper explanation for why cylinders 1 and 2 generally have lower compression than 3 and 4?
Old 10-30-2007   #9
Scrmegl
Brian
Scrmegl's Avatar
Danger Wheels Champion!
Drives: '98 TSI AWD
Send a message via MSN to Scrmegl
My #2 plug discolors first on a plug swap every time. Not major but noticeable. I always heard the same things. Some myth busting on this would be great.
A Body to G Body to F body to 2G DSM
Scrmegl is offline   Reply With Quote
Old 10-30-2007   #10
HAHA lean cylinders from fuel distribution!
Man tooners must be busy...
Old 10-30-2007   #11
So...what is the reason behind some cylinders running leaner than others?
Old 10-30-2007   #12
Actually, you guys sound like starquesters, who really do have fuel distribution problems.
Old 10-30-2007   #13
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
I thought it was because of air flow as well. Wouldn't that be more of a problem then fuel?
Would buying a bigger fuel rail just solve this problem?
I suppose this become a problem when running E85 and lots of fuel
Old 10-30-2007   #14
TBI for the ultimate loss
Old 10-30-2007   #15
No plenum to speak of, injectors before the TB, tri-y intake design. w00t. dsm people have it easy.
Old 10-30-2007   #16
blageo23
AWD4G64
blageo23's Avatar
Lean=not enough fuel, no matter how you slice it.
Old 10-30-2007   #17
Yes, but it has nothing to do with the fuel system. We met a Pro Mustang drag racer last year at PRI who was in a class that didn't allow individual cylinder trimming. He drilled holes into each intake runner and screwed bolts in and out to block airflow to cylinders that got too much air and melted shit.
Old 10-30-2007   #18
Wouldn't that be "trimming" the cylinders, just in a caveman-style way?
Old 10-30-2007   #19
Airflow. It is much harder to get perfect air distribution to 4 cylinders through a throttle body, plenum, runners, intake port, past the valves, in an environment that is always changing. Versus a straight tube in which the pressure delta should always be the same, unless the fuel pump can't keep up. Even regardless of airflow, temperature can cause one cylinder like #2 to be more prone to detonation, because it is sandwiched between 2 other hot cylinders. Often with a standalone system, you might give more fuel or less timing to the center cylinders. The 03-04 Supercharged Cobra has 2 cylinders on side of the motor that are most likely to go first because of the stock cooling system.
Old 10-30-2007   #20
Thanks Shane .
Cooling (heat dissipation) and airflow (aka more than adjacent cylinders) are reasons why some cylinders are more prone to detonation.
Also exhaust manifold design can also play a role in detonation prone cylinders (yet again that is airflow).
Pressure drop across a fuel rail isn't going to be severe, even with garden hoses and minimal fuel pressure. Now if we low volume flow/extremely low pressures+massive injectors we could run into a starvation issue, but this isn't the case on dsm's.
Ebay owns!
