Old 06-30-2008   #1
2JZ vs LSx, opinions, knowledge, and of course the smart (*& comments too.
Pondering the powerhouse for my next project.
any educational info on the 2JZ is most welcome.
Old 06-30-2008   #2
Re: 2JZ vs LSx, opinions, knowledge, and of course the smart (*& comments too.
Well wtf do you want to know? They make power and the 6spds are really expensive.
Old 06-30-2008   #3
Yea, mating a decent tranny and clutch to it can be very expensive. If you only want 750hp or less, you might be able to use a cheap R154 tranny though. The very HP guys usually run a Chevy auto like a TH400 or Powerglide.
Old 06-30-2008   #4
2JZ is very heavy. It isn't the most efficient motor ever, not so great mpg and a not the best head design ever. You can get around it by cramming shit load of boost down it like every one with a Supra does and make all kinds of power. Cams and aftermarket intake manifold can help them a lot. They can handle all kinds of power in stock form, if it's an older motor. The newer IS300 2JZ motor has a better head and VVTI, but a weak bottom end. You can also run the NA version of the 2JZ, you just need to buy a Cometic HG for it to lower the compression. Throwing in a stock GTE headgasket will also lower the compression on that motor a decent amount, but not enough to make me happy on pump gas at higher boost. It would probably be decent for E85, but a Cometic doesn't cost much more than a stock HG anyways. The GTE is COP vs a distributor on the GE motor too. The distributor can get in the way for big turbos that run a 5" inlet, if you are running an intake pipe.
Old 06-30-2008   #5
I think that R154 has been used on starquests before. I should look into that if I start breaking transmission. And I'll never make 750 so that's cool.
Old 06-30-2008   #6
I do not enjoy your binary sig.
Old 06-30-2008   #7
hippiekiller
hippiekiller's Avatar
What's it going in?
There is a guy that posts on WIDSM that is putting a 2JZ in a Starquest...Interesting little project.
hippiekiller is offline   Reply With Quote
Old 07-01-2008   #8
dumb_ricer
Hates Everything
Drives: Neon
Send a message via AIM to dumb_ricer
depends what the plans are for the car.
2JZ's will make high power more easily than an LSx, but if you want handling you will probably have better weight distribution/torque curve for road racing or whatever out of a LSx. They fit in anything, and can easily make 450+whp NA all day every day, and love it.
Trans options are all over for the LS1, and clutches aren't too expensive. Also easy to run an auto if you want to go that route.
Depends what you are looking for.
Drag car would be 2JZ for me, head/cam/nitrous LSx for just a fun vehicle.
420A > LS1 > All Else
I > All else
dumb_ricer is offline   Reply With Quote
Old 07-01-2008   #9
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
TT LSx= Wheelie poppin 280
Old 07-01-2008   #10
At-Least-It's-An-Evo
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
na-t a 2jz. It's so cheap, it should be put in every car that it'd fit in.
Old 07-01-2008   #11
Duh, 4G63....what is this project anyways, an ultima kit car?
http://www.ultimasports.co.uk/usa/
Old 07-01-2008   #12
TT a LSx, they make loads of power. Yes you have to build it, but it is a chevy so parts are cheap. Tons of aftermarket and you can make it a 427ci or 454ci while you are at the build. Now you are talking, 2.5 times the size of the 2jz!
Old 07-02-2008   #13
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Old 07-01-2008   #14
thanks guys, been talking to a few more people on both sides and i have chosen the LSx.
Old 07-01-2008   #15
No replacement for displacement.
Old 07-01-2008   #16
Good choice, my next project will be LSx powered also, but that is a ways down the road. So what is up your sleeve?
Old 07-01-2008   #17
Probably LS2 bolt-ons. should be enough for a bit. oh and enjoying doing burnouts
Old 07-02-2008   #18
GSXMatt
You can't buy my Evo.
GSXMatt's Avatar
Drives: 03Evo,11Altima
Send a message via AIM to GSXMatt
2jz no shit.
99 GSX- Sold
03 Evo- More than stock.
-ATC Productions-
is dead.
I hate Mitsubishi.
GSXMatt is offline   Reply With Quote
