08-11-2008
Drives: 98 GSX, 04 is300
98 GSX ecu in a 95 talon awd???
How can I make this work??? I want to swap out the ecu so that I can use dsm link and my gf doesn't need it
So far I know that I have to swap like 2 spark plug wires but what else is there and if that is it then which 2 wires do I swap?? thanks
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
08-11-2008
Re: 98 GSX ecu in a 95 talon awd???
bump I need the info..
98 GSX (built)
03 BBY EVO dd
08-11-2008
You swap plug wires 1-4 and 2-3 and you can also swap the injector wires on the harness that plugs into the ecu for better idl and overall running.
Amsoil Dealer
08-12-2008
Can you specify for the injector wires please... what do you mean exactly??
98 GSX (built)
03 BBY EVO dd
08-12-2008
You don't have to swap the injector wires, if you get DSMLink. You can just pick "Invert CAS" in DSMLink. You still need to swap the spark plug wires around though.
08-12-2008
But what he wants to do is steal his girlfriends Eprom ECU and replace it with his.
Do what Kerry said and you should be fine.
1998 Spyder AWD
567hp
490tq
08-12-2008
LOL Ok I will but you can show me what you are talking about with the injector wires...
98 GSX (built)
03 BBY EVO dd
08-12-2008
Drives: 91GSX; 98 GSX; 92 Tsi AWD; Kawasaki ZR7
You just swap 1&2 and 3&4, just like the plug wires. The injector wiring should be long enough if you just turn each injector slightly, that's how I did mine.
08-12-2008
Can't you also swap the wires on the ECU?
08-12-2008
Ya I was thinking that was what they ment by it?
98 GSX (built)
03 BBY EVO dd
08-12-2008
Amsoil Dealer
08-12-2008
So what your saying is I have to do more then just swapping the plug and injector wires??? Or is that something different??
98 GSX (built)
03 BBY EVO dd
08-13-2008
No you swap the plug wires 1 and 4 with wires 2 and 3. Then just do the injector wire swap on the harness that plugs in right at the ECU.
Amsoil Dealer
08-13-2008
Ok sounds good thanks for the info!! do I swap the same numbers in both?? that is what I assume...
98 GSX (built)
03 BBY EVO dd
08-13-2008
I think but I am not sure.
Amsoil Dealer
08-13-2008
Well thats what I'm going to do.. and I can do this and run it without dsm link for a while right then install it? and when I install it I wouldnt have to change anything...
98 GSX (built)
03 BBY EVO dd
