Old 08-25-2008   #1
mdost03
Sonic Champion!
Drives: VA STI
Question on MAP built shortblocks.
Is there any type of warranty on these? Rings are shot on mine.
Old 08-25-2008   #2
Re: Question on MAP built shortblocks.
I don't know if it's ok for me to post this, is there anything you did to cause the rings to fail versus an assembly error?
Old 08-25-2008   #3
mdost03
Sonic Champion!
Drives: VA STI
Basically bought it from a member and it was tuned by LSE. Never really ran quite right and would blow smoke once in a while. Got worse and worse until I finally did a dry/wet compression test on it. I personally didn't do anything to make it like it is, but figured I would ask before I start throwing more money at it (which I was planning on).
Old 08-25-2008   #4
v8klla
v8klla's Avatar
Unfortunately warrantying short blocks is very hard to do, especially so far down the line. We definitely stand behind our work and in the event that a short block of ours was to fail due to assembly we would definitely repair or replace it, but a failure like that would occur almost immediately. In our experience most short block failures are caused by lack of oiling, overheating, detonation, or other abuse. Sounds like yours had a rough life before you got it...
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 08-25-2008   #5
It's one thing to maybe ask for a warranty on something you bought directly from a vendor, it's something different to ask for one on a used part. I'd just hone and re-ring it if the cylinder walls look okay.
Old 08-25-2008   #6
mdost03
Sonic Champion!
Drives: VA STI
That's what I am planning on doing, figured I would inquire before tearing it all apart though. Thanks.
Old 08-26-2008   #7
One more thing on warrantying shortblocks. It is also very hard to warranty a short block when it crosses shops. If break in procedures are not followed according to the manufactures specifications, it is difficult to see how everything was used.
Also one more thing, just because a car was tuned, doesn't mean it ran perfect before it was tuned, or ran great after it was tuned if parts changed.
Old 09-24-2008   #8
mdost03
Sonic Champion!
Drives: VA STI
Figure I would give an update.
Turns out (99% sure) the shortblock is okay, the head had a very bad blown headgasket according the machinist. Said from working on it, the head must have just been put on hand tight with a ratchet and called good, didn't torque it. Plus, the valve stem seals were pretty bad on there which was my oil problem out of the exhaust ports.
I ordered rings from you guys that had to be special ordered from Mahle, is there any way to return those or since it was a special order, the sale is final?
Old 09-24-2008   #9
v8klla
v8klla's Avatar
We can touch base with Mahle and see if they will take them back, but if they do there will likely be a hefty restocking fee Let me know.
P: 763-545-3800
Old 09-24-2008   #10
mdost03
Sonic Champion!
Drives: VA STI
Well if you could check on that, that would be great. I doubt I will use them so any money back is better than having the rings sitting here.
Old 09-25-2008   #11
311evo
311evo's Avatar
if there is a crazy restocking fee, i would think you could re-sell them remotely easily.
Old 09-25-2008   #12
Thought I'd throw in my .02 cents. I have a MAP built shortblock, and they've gone out of their way before to double check things for me when I was uncertain. I wouldn't have to think twice on where to go to have another one built. They've been a huge help for me and I would recommend them to anyone local looking for engine work done.
Old 09-25-2008   #13
311evo
311evo's Avatar
just like this thread, the map built short-block is A-Okay! its just whomever assembled the engine after the got the shortblock from map didnt take their time.
Old 09-25-2008   #14
v8klla
v8klla's Avatar
Thanks for the kind words Brandon! In regards to the restocking fee it looks like Mahle wants 25% plus they wouldn't reimburse us for shipping here or back
P: 763-545-3800
