Old 11-01-2008   #1
OmgAwd
OmgAwd's Avatar
Drives: 1992 Eagle Talon TSi Awd
Best way to get oil pressure up before starting up?
I just rebuilt my bottom end and reinstalled my turbo so I need to get my oil pressure up before I start it. What is the easiest way to keep it from starting?
If it's by draining the fuel line and disconnecting the pump what is the easiest way to kill power to fuel pump temporarily?
This is for a 1g.
OmgAwd is offline   Reply With Quote
Old 11-01-2008   #2
brando
Drives: gutlass
Re: Best way to get oil pressure up before starting up?
wtf are you talking about? oil pressure is gained almost instantly.
Old 11-01-2008   #3
OmgAwd
OmgAwd's Avatar
Haha. So that would be why I didn't find any info on this.
Old 11-01-2008   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
The general rule is the engine should recieve oil pressure within the first 3 seconds of startup. But to build pressure without starting it take out your MPI fuse located on the positive terminal on your battery. This should also be done when putting in a new turbo to get oil to the bearings.
-1990 Mitsubishi Cyborg 4WD-
Old 11-01-2008   #5
I do it by taking out the spark plugs and injectors and cranking the engine for a while. It shows a tiny bit on the guage in my car.
Old 11-01-2008   #6
SnoEclipse
Drives: 07 Eclipse GT
did you use any assembly lube when you put the motor back together??
07 Eclipse GTV6 Deep Red Pearl, cosmetic and weight reduction mods in progress, suspension and brakes come in Spring 2009. I want an LSD for the 5 speed auto!!
SnoEclipse is offline   Reply With Quote
Old 11-01-2008   #7
The assembly lube will provide more than enough protection until the oil gets circulating. The quickest way to circulate oil is by starting the engine.
Old 11-02-2008   #8
On my engine build i spun the oil pump sprocket with an electric drill before i put the Tbelt back on and put the engine back in the car.
When it was back in the car i pulled the EFI fuse and put the turbo feed hose into a cup. Spun the engine over with the starter to make sure oil filled the cup and indeed it did. Attached feed back to turbo, run car.
Old 11-02-2008   #9
OmgAwd
OmgAwd's Avatar
Duh!
Old 11-02-2008   #10
OmgAwd
OmgAwd's Avatar
I was more worried about the turbo since the feed line would be empty for a pretty significant amount of time. Thanks for the help, guys.
