Closed Thread
Old 11-19-2008   #1
JuIcEyEVO
Drives: 1994 Mitsubishi Mirage
Cool JDM Motor Mount Question
If I get Mitsubishi Evolution 3 motor mounts from japan tonight (AND I CAN) will I go to bed soundly knowing that I should have no problem mounting a 1g 6bolt 4g63t engine into my 94 Mirage sedan?
Juicey
JuIcEyEVO is offline
Old 11-19-2008   #2
eagle talon guy
eagle talon guy's Avatar
Send a message via AIM to eagle talon guy
Re: Yoda was cooler than darth vader
......Nice thread title....
-Michael
(^^very old pic!)
6 Bolt build in progress
eagle talon guy is offline
Old 11-19-2008   #3
JuIcEyEVO
........Nice name title.........
Old 11-19-2008   #4
Whats the hesitation then?
sleepydsm is offline
Old 11-19-2008   #5
JuIcEyEVO
Whats the assumtion that I have an engine yet? It was just a simple question.
Old 11-19-2008   #6
Mabe you should look on here first and ask the guy who has done it already. Also if you have to ask you should not be trying to do this kind of swap to start with.
TkrPerformance is offline
Old 11-19-2008   #7
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
with a lightsaber...possible, it should be.
ლ(ಠ益ಠლ)
awd-drifter is offline
Old 11-19-2008   #8
cmspaz
Walls need hugs too
cmspaz's Avatar
Oh man, he wants motor mounts from JAPAN. That's JDM TYTE!
Because you can't use motor mounts from, say, another 4G63 car... that would be absolute absurdity.
Originally Posted by Trogdor
cmspaz is offline
Old 11-19-2008   #9
to be nice no just buying the mounts will not help you out at all just to bolt it in. you need to fix the title ask a real question and the Swap King might help you out.
all we know is that you have a
94 rage
want to put in a 6bolt
and want jdm mounts
do you know what wiring harness to use and how to wire it in to the rage dash harness
what tranny are you going to try to use.
what other mounts are you going to use
it is not a easy swap for some one that does not have a clue and have to ask about mount to start with
if you do a search on here there is 2 swapped mirages on here that have been built and being built
Old 11-20-2008   #10
Re: Jdm Mounts
Originally Posted by JuIcEyEVO View Post
Do mark a favor. Lock this thread
I'll do the board a favor and just delete your posts
Kracka is offline
Old 11-20-2008   #11
Mark FTW!
I think the point is you are just scratching the surface with that question. Dig deeper, young jedi mind trick eraser....
scheides is offline
Old 11-20-2008   #12
I'm editing your thread title this time only. Next time the thread will be deleted; especially in the tech section.
Kracka is offline
Old 11-20-2008   #13
Re: JDM Motor Mount Question
l...Overnight.....................l ll
l....Parts From Japan..........ll'l'';,_
l_..._...___________====ll_l_l...,]
''(@)'(@)'''''''''''''''''''*l(@)(@)**'(@)
Kevin 1G Drummer is offline
Old 11-20-2008   #14
I need two bottles of NAWZZ, and I need them by tonight.
Goat Blower is offline
Old 11-21-2008   #15
Dumbass banned; thread closed.
Kracka is offline
Closed Thread
