Old 11-20-2008   #1
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Compression numbers
I did a compression test on the Galant today
Cylinder # 1 @ 109
Cylinder # 2 @ 110
Cylinder # 3 @ 145
Cylinder # 4 @ 130
Are these numbers good?
Old 11-20-2008   #2
Re: Compression numbers
You should have posted this in the shoutbox.
Nice numbers!
Old 11-20-2008   #3
Hmm, they seem a little low to me. And shouldn't they all be within 5% of eachother?
Old 11-20-2008   #4
Let er buck.
Old 11-20-2008   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Let er buck.
Will do!
That seems to be the DSMer motto.
Hell, I say turn the boost up now and see what happens
It's already running 28psi on this pewpy E70. I wonder how 30+ would do
Old 11-20-2008   #6
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
30+...is the flux capacitor in good working orders? lol, jk.
OP, I'm also going to do a compression test pretty soon. aren't good numbers like 150 across???? or between 120-130??? i remember seeing something like that on VFAQ...
ლ(ಠ益ಠლ)
Old 11-20-2008   #7
joem
Drives: 1991 Talon awd auto
150 is the JDM numbers and anything with compression in our USA DSM's is good just to clear that up. Lower compression means to turn up the boost.
For every 5 psi low turn boost up 1 psi.
Joe
Old 11-20-2008   #8
best numbarz evarz
Old 11-20-2008   #9
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
#3 and 4 need a bit of sand. Then you can turn the boost up some.
Old 11-20-2008   #10
Haha I guess this went over my head for a minute there. Hell, I say turn the boost up now and see what happens
Old 11-21-2008   #11
311evo
311evo's Avatar
every compression gauge reads different, as long at they are all in 5-10psi of each other you're usually good.
Old 11-21-2008   #12
lol, this thread is awesome.
Anywho, looks similar to my old numbers. Unless you are trying to get every ounce of power of the motor, don't worry about it and go have fun.
Also you always need more boost.
Old 11-21-2008   #13
moar boost!
Nah, leave it, rock it. When the HG was leaking on my evo a few weeks ago, my numbers were: 182 175 180 175
Old 11-21-2008   #14
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
more boost. It solves everything.
'04 Honda Ricer: stock
Old 11-21-2008   #15
iceminion
iceminion's Avatar
You could always hone and re-ring.....or you could just turn up the boost.
Lower compression = safe to boost moar!
building a 3000GT AWD Turbo.
Old 11-21-2008   #16
By the book the best the compression could be is 165 psi 7.8:1 pistons, service limit is ~110psi or if cylinders are not with in x% of each other. As long as it runs good, makes good power, etc I would not worry about it.
Old 11-21-2008   #17
brando
Drives: gutlass
lower compression also mean's bad ring's possible bad hg or maybe something else. i would check for blow by. usually you should be at like 150-160
Old 11-21-2008   #18
iceminion
iceminion's Avatar
I need to emphasize that if you car runs fine, don't worry about it, you can have loads of fun (400AWHP+) on a stock block with badBAD blowby.
yes, the service manuals are saying 150PSI+ with a compression variation of 10%, but whatever, they are not running 30LBS of boost.
Old 11-21-2008   #19
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Leak down test. Maybe you'll get lucky and just need head work.
Old 11-21-2008   #20
brando
Drives: gutlass
blow by is not a good thing. and more boost doesn't drop compression. it may be running fine now but who know's. mine ran perfect then one day bam there goes a head and i was having the same problem's with weird compression. you all can say "its fine run it" or "turn boost up while you can" im just gonna say that i told you so right now before your stranded on the side of the road with a trail of parts/fluids behind you.
if you fix this compression problem you will notice instant performance gains at the same boost level's
