Old 12-01-2008   #1
OmgAwd
OmgAwd's Avatar
Drives: 1992 Eagle Talon TSi Awd
Is my wastegate shot?
Today I tested the wastegate actuator on my 1G.
Results - 12.5psi it started to open and was fully open at 15.5psi.
Time for a new one?
OmgAwd is offline   Reply With Quote
Old 12-01-2008   #2
Re: Is my wastegate shot?
Why do you think its shot? Sounds like its functioning perfectly to me.
Old 12-02-2008   #3
OmgAwd
OmgAwd's Avatar
It's supposed to open at 11 and it seems like I'm making way too much boost. I know I shouldn't trust the stock gauge but it keeps going past max. I'll get an aftermarket soon.
Old 12-02-2008   #4
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Uh... did you make the numbers up?
'04 Honda Ricer: stock
Old 12-02-2008   #5
OmgAwd
OmgAwd's Avatar
What?
Old 12-02-2008   #6
If you changed the stock exhaust or intake system piping, then it will make more boost than stock.
Old 12-02-2008   #7
OmgAwd
OmgAwd's Avatar
My exhaust and intake are not stock but I tested the wastegate actuator with it off the car on an air compressor!
Old 12-02-2008   #8
The stock gauge guesses anyway.
Old 12-02-2008   #9
A wastegate on a car under boost will open earlier than it will on the bench do to backpressure pushing the flapper open. The backpressure essentially makes it act like a weaker spring.
When you put aftermarket exhaust on a DSM it makes the car run more boost, sometimes to the point of uncontrollable boost creep.
Old 12-02-2008   #10
OmgAwd
OmgAwd's Avatar
Thanks.
I'm picking up a boost gauge tomorrow.
Old 12-02-2008   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Get a real boost gauge before you make any more assumptions.. The stock gauge does nothing for you.
-1990 Mitsubishi Cyborg 4WD-
Old 12-02-2008   #12
OmgAwd
OmgAwd's Avatar
I know that the stock boost gauge does nothing. I stated that.
