Old 12-17-2008   #1
Batmobile2417
Drives: 92 Talon Work in Progress
Valves hitting pistons
I have a 1991 eagle talon (2.0 turbo that the timing belt snapped and hit the pistons. I was wondering the exzact damage. I of coarse know that the head and timing belt have to be replaced however how does this affect the pistons. I can see where the valves hit them. Will this affect the engine afterwards?
Batmobile2417 is offline   Reply With Quote
Old 12-17-2008   #2
Re: Valves hitting pistons
It depends on how bad the pistons hit. Put up some good close up pictures of each piston. It will create a weak spot in the piston, if the car is only going to be pretty stock, they are normally ok with a light hit. You will want to file down and polis the lip that was created with the hit. It might be a good time to freshen the engine and put in some 2g pistons too.
Old 12-18-2008   #3
jhaan_dude
jhaan_dude's Avatar
Drives: a car
OR BUILD THE SHIT OUT OF IT, AND WASTE ALL YOUR SAVING INTO MAKING IT HELLA FAST!!!!
well at least thats what i would do if my car was gonna be down for a few days....
Old 12-20-2008   #4
Batmobile2417
haha that is the best way too go!!
Old 12-18-2008   #5
SnoEclipse
Drives: 07 Eclipse GT
bent valves, split valve seals, etc, etc.
If anything chipped off a valve you'll have scored cyl walls and maybe a cracked ring.
07 Eclipse GTV6 Deep Red Pearl, cosmetic and weight reduction mods in progress, suspension and brakes come in Spring 2009. I want an LSD for the 5 speed auto!!
SnoEclipse is offline   Reply With Quote
Old 12-18-2008   #6
Like Jet said, it depends upon the severity of the hit. I've seen pistons cracked from valves slamming into them, and I've pulled apart perfectly running engines and seen valve damage on the pistons from previous repairs.
Old 12-18-2008   #7
What do you mean split valve? The head of the valve came off? If so then the head and pistons are probably junk.
Old 12-18-2008   #8
I think he was talking about cracked valve seats, which I have not seen yet from "just" bent valves. The bottom of the valve guide will crack if the valve is bent enough, but I do not think the valve seal would be damaged unless you had a keeper/retainer issue.
Old 12-18-2008   #9
brando
Drives: gutlass
please post pics of said damage. you might be fine. usually nothing super major happens but every once in a while you get some good chunks taken out
Old 12-20-2008   #10
Batmobile2417
Well here they are!! Doesn't look like engine is damaged. You see all pistons, the broken head, and the new one
ID:	8061   Click image for larger version
ID:	8062   Click image for larger version
ID:	8064   Click image for larger version
ID:	8065   Click image for larger version
ID:	8067   Click image for larger version
ID:	8068   Click image for larger version
Old 12-20-2008   #11
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
File down the pistons where they had contact with the valve. Other than that you'll be good to go.
What the hell is all over your engine bay? Looks like metal shavings or over spray...
Originally Posted by shoutbox
Old 12-20-2008   #12
Batmobile2417
Ya that was all the gunk that was left over from a junk head gasket that I had to grind off. Now I am just lining up everything to slip on the timing belt and the cams want to turn about 2 to 3 turns off of their mark. Is there a trick to keep the cams and the crank in the correct location while you get the belt and tensioner on correctly?
Old 12-20-2008   #13
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Wait... "Grind off"???
I hope you meant "scrape off". Grind and head gasket do not go together.
I'm guessing you mean the cams want to move 2-3 teeth from their mark. You can put the belt on one cam gear, zip tie it, then move the other cam gear with a wrench and zip tie the belt to it when lined up.
Old 12-20-2008   #14
ahh, he probably used an air grinder and hopefuly a soft disc and removed the stubborn gasket, not what I would have done, but as long as he uses a stock style headgasket he should be fine. I'd also reccommend coating it with "Copper Spray" which you can get at your local parts store.
Old 12-20-2008   #15
Batmobile2417
Yes I did use an air grinder with a very very very soft disk. I have cork like plugs that block off all the holes in the block so that nothing gets in. Yes there was a stock head gasket in there and yes I already used that copper spray a gaket. I love that stuff!! I will try the zip tie trick. Right now i was just trying to line up the marks on the bench. I will make it work thank you
Old 12-20-2008   #16
Wow, those valves hit the pistons pretty hard. I wouldn't reuse them, but I guess worst case scenario you have to redo the engine. Good luck!
