Old 12-15-2008   #1
Cold weather issues?
I've already read one thread about the doors freezing shut so I figured I'd make a thread regarding cold weather issues.
I'm happy to report I've had none! The mini-battery has been able to fire the Evo up easily even with the FP4R cams and FIC 850cc injectors. After a few seconds of warming up it idles smoothly and drivability is fine. Also, the Redline tranny cocktail is shifting very smoothly in these below-zero temps.
Old 12-15-2008   #2
ylimert01
ylimert01's Avatar
Drives: Nissian
Re: Cold weather issues?
My door locks were screwed up this morning could not get the car unlocked, at first thought it was frozen shut, but when I came home they worked just fine..I had to get a ride to work and was 5 mins late.
F Subarus!!!
-Emily
Old 12-15-2008   #3
I can't open my mail box. Our mail boxes are small metal boxes outside that you have to open with a key. I was able to finally get the key in, but could not turn it. Guess I'll have to wait for a warmer day...
Old 12-15-2008   #4
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
I have none so far and everything running great! A lot of door problems hope no one else has them.
Old 12-15-2008   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
That was me with the frozen doors. haha, But yea other than that no other problems!
-1990 Mitsubishi Cyborg 4WD-
Old 12-15-2008   #6
I'm finally able to park my car in a garage this winter and I love it! It's not heated, but it doesn't seem to get below freezing in there. Most of the snow melts off the car overnight, then doesn't freeze on the floor. No frozen doors or locks for me. The car did turn over a little slowly when I was leaving work, but that's probably cuz I still have Shell 10w30 in it. I'll probably have to change the oil sometime soon.
Old 12-15-2008   #7
I've been thinking about switching to 5W-30 for the winter instead of my usual 10W-30, but after today I'm thinking its not needed.
Old 12-15-2008   #8
This Shell Rotellla oil I'm using seems to be thicker than other types of 10w30 I've used. I get way better oil pressure with this than any other 10w30 I've used.
Old 12-15-2008   #9
I used to use Rotella in my DSM's and noticed the same things. Great oil but probably a tad on the thick side for winter.
Old 12-15-2008   #10
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
I thought Rotella was mainly for diesels
Old 12-15-2008   #11
Its designed for heavy-duty diesel applications but is a great oil for turbocharged extreme-duty gasoline applications.
Old 12-15-2008   #12
twack
It was a auto get over it
twack's Avatar
think my battery in the liberty is crap cause when its super cold out its dead
Old 12-15-2008   #13
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
My bronco wouldnt start at all this morning, I almost missed a final because of it.
BLaCk_1cE is offline   Reply With Quote
Old 12-15-2008   #14
I haven't started my car in almost week now, I should probably check to see if the battery is dead before work tomorrow morning. It does have a hard time starting in this extreme cold, like a full 4 or 5 seconds of cranking. However the e70, 1600s, and no FIAV probably don't help one bit.
Old 12-15-2008   #15
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
My only problem is I seem to have lost my car. I parked it in my lot the other day and now there is a large mound a snow where it once was. Keep an eye out for a purple dsm
pics or gtfo
Old 12-15-2008   #16
I had a wiper break today from being frozen to the windshield.
Old 12-15-2008   #17
^never seen that.
Everything started ok, a bit slow, but the rolla only put out cold air after work until about 10 mins of driving then warm, I had it running for 15 min before i left work.
Redline cocktail? care to share? 2 MT 90 1 MTL?
I was talking about hill, I use rotella to up OP.
Old 12-15-2008   #18
Correct! Two quarts of MT-90 and one quart of MTL. This is my recommended mix for all Mitsubishi 5-speed transmissions calling for a GL-4 gear lube. Now, for Hondas, go for straight MTL
Old 12-15-2008   #19
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I'm running the Redline cocktail! Woot!
My tranny went from forcing it into every gear to smooth as butter..
Old 12-15-2008   #20
SnoEclipse
Drives: 07 Eclipse GT
I've got 5w20 Mobil1 in my 4g 3.8l. No starting problems at all the past two days. I run my oil for 12k miles and change filters at 3k and add as much oil as necessary. The current fill has 6k miles on it.
If I'm leaving from the house garage I idle something like 30 seconds. Parked at school tonight (-6f on the idiot box) I sat for a full minute before heading off. No weird noises from any part of the car, no weird shifting from the sportronic tranny, brakes fine, etc.
07 Eclipse GTV6 Deep Red Pearl, cosmetic and weight reduction mods in progress, suspension and brakes come in Spring 2009. I want an LSD for the 5 speed auto!!
SnoEclipse is offline   Reply With Quote
