Old 10-26-2008   #1
kevbo6204
kevbo6204's Avatar
Drives: #313/1000 '92 Summit White VR4 Galant
'92 Mitsubishi Galant VR4 313/100
So the time has come to sell the car. First off, as you can tell from the photos the car has been in an accident. Trust me I almost cried when I got in the accident and it was just a stupid mistake on my part in a really bad situation to begin with. Anyway the front of the car hit the side of another car going roughly 5mph and the other car glanced (tbone situation) I am a strong believer in not parting these cars out, that is why I am not doing it. The car drives fine still. However it does track slightly left. I would like to give someone the chance to fix it for way less than what I paid. My price is firm at $2000. Thanks for looking. PM with any questions I will respond promptly. Car is located in Minneapolis.
1992 Mitsubishi Galant Vr4 #313/1000
Engine:
(Engine was rebuilt due to melted piston)
Bored .020
Forged 8.3:1 wiseco pistons
Head and block decked for Cometic MLS head gasket
Reconditioned stock rods
ARP head studs
Head lightly ported
Head reconditioned(new guides,springs, valve job, etc.)
New front case(oil pump)
Balance shafts removed
All new timing components and water pump
All bearings and gaskets etc.
Rebuilt 14b turbo
Performance:
1G steering wheel and shifter
Gasket matched intake
Gasket matched 2g exhaust manifold
Ported turbine housing and Evo3 O2 housing
Custom 3" turbo back exhaust with magnaflow muffler
Auto meter gauges mounted in dash(boost,oil press,oil temp)
Fuel Pump rewired
Just added
Keydiver Stage III chip
Fresh cleaned and flowmatched 560cc Evo 8 injectors
3g mas with brand new kn filter
Replaced:
New Valve cover gasket
All hoses radiator hoses replaced
Throttlebody just cleaned and new seals installed
Front ball joints
Power steering pump and rack
Rear brake calipers and brake pads all around at 140k
All 4 brake rotors
Parking brake cables
Clutch master cyl. and slave cyl.
4 tires(Fuzion HRi) at 150k
Trans:
Shifts through all gears fine, 2nd is notchy at high rpm's
Clutch feels strong and has never slipped but i do not know the mileage
Suspension:
KYB GR2 struts on stock springs
Rides decent and handles well
No loose tie rods, ball joints etc.
4WS is disabled and has a non 4WS rack in it
Misc:
A/C is disconnected
Kenwood stereo with ipod adapter and aux input
Pioneer speakers
Thule rack is NOT included
More info and pics here: http://www.galantvr4.org/ubbthreads/...ev=#Post628497
kevbo6204 is offline   Reply With Quote
Old 01-02-2009   #2
kevbo6204
kevbo6204's Avatar
Re: '92 Mitsubishi Galant VR4 313/100
Bump for new parts put on!
Old 01-02-2009   #3
iceminion
iceminion's Avatar
From one VR4 owner to another....now that it has a fairly large blemish get that sucker back on the rally track where it belongs!
building a 3000GT AWD Turbo.
Old 01-02-2009   #4
I'm sorry, but that car is not worth $2500. The front end is swayed way over to the left, as you can tell by looking at the fenders. There's an easy $8k in damage there.
Old 01-02-2009   #5
kevbo6204
kevbo6204's Avatar
$8k? To hang new panels and throw it on a frame rack I was quoted no more than 2k from the highest person. Maaco gave me a quote of 800 bucks for all work if I provided the panels. The car runs perfect. Alignment wise the front is dead nuts. Ask pete on here (polishmafia) he did the alignment about a month ago.
Old 01-03-2009   #6
polishmafia
Smells like cat poop
polishmafia's Avatar
The alignment is dead on for how the car is. I doubt the frame is bent enough to cause problems, since the alignment was not far off at the initial settings - I've seen far worse from everyday DD cars off the street. From what I saw, 95% of the damage is cosmetic.
Old 01-04-2009   #7
kevbo6204
kevbo6204's Avatar
Thank you Pete
Old 01-04-2009   #8
The upper rails are bent for sure. And I'd bet the lower rails are also bent a little. Probably mostly infront of the strut towers. I do body work for a living, so I think I might know what I'm talking about. And as far as your Maaco quote, I would never take a car to Maaco for any kind of structural repairs. I've seen some pretty hacked out stuff come from there. I could get a better idea of the damage if you posted a pic with the hood open.
Old 01-04-2009   #9
Gvr-4
I hate to see our cars get hurt, good luck with the sale, if I sell my eclipse soon ill give you a call.
Gvr-4 is offline   Reply With Quote
Old 01-04-2009   #10
kevbo6204
kevbo6204's Avatar
Im not questioning your opinion on the extent of the damage. I just found it interesting how quickly you can give me an estimate by looking at a picture without seeing it in person or under the hood. You usually have to bring it in to get an estimate instead of emailing a picture of the front Yes the radiator support is bent yadda yadda yadda. I dont have anything to hide about my car. If someone is interested they will ask more questions and for more pics. I hope we can now move on.
Thanks,
Old 01-04-2009   #11
kevbo6204
kevbo6204's Avatar
Trust me it makes me sick. When it happened I wanted to throw up. Good luck with your sale as well.
Old 01-05-2009   #12
I'm not trying to be a dick about it or anything, I just wanted to make sure someone who would potentially buy the car isn't getting in deeper than they were expecting. And yeah, that 8k figure I threw out was probably a little on the high side, but I was just comparing it to other totals I've seen from similar damage.
Old 01-05-2009   #13
john
Business as usual
john's Avatar
I did some auto body work in High School and if your shop would quote $8k for that, you are way over priced. Obviously it will need some work on the core support but there is no where near the damage you are thinking.
I don't think this is a bad deal at all considering the rarity of the car and the engine work. Someone who has some autobody experience and looking for a VR4 would be all over this assuming they didn't want a stock car. Hell, a stock VR4 just sold for $4300 on here and most people on here would prefer some engine work.
I don't know the seller, just stating my opinion on the vehicle/price.
97 Viper GTS
Old 01-05-2009   #14
Gvr-4
I dont know the guy selling the car, but I'm sure that the damage isn't that bad, I went to school for auto body and it looks like a little hammering and body parts. and Im sure that kevin_1g_drummer didnt mean to come off as a bad guy or anything, so lets just get back to the topic, we have 2500 here, do I hear a 3000?
Old 01-06-2009   #15
kevbo6204
kevbo6204's Avatar
First $2000 takes it!
Old 03-05-2009   #16
kevbo6204
kevbo6204's Avatar
First person this weekend only with cash in hand takes it for $1500.
Old 03-06-2009   #17
johnson
johnson's Avatar
Drives: 90mitsu
i would have taken this for 1500?
damn....
would have been a good donor!
Old 03-14-2009   #18
2gREDTsI
Oh man, I offered you 1800 for it. To late now I am kinda into another project well see what happens.
2gREDTsI is offline   Reply With Quote
Old 03-16-2009   #19
kevbo6204
kevbo6204's Avatar
Car is sold!
