Old 02-20-2009   #1
valve cover with big breather lines.
Can you guys post up pics of where people usually put the upgraded "breather" lines in the the valve cover on DSMs, i got an extra valve cover that I want PC'd and i want to put bigger lines in cause i am tired of the dipstick doing all the venting for me.
Thanks.
My Catch can is right in front of the stock battery, on top of the tranny pretty much.
Old 02-20-2009   #2
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: valve cover with big breather lines.
swing by if you wanna really look at it. or go on talk. mine is where the stock ones where, just welded some fittings on, then drilled out the center to match the bung. Others do a 90 off the top of the vc (not as clean IMHO) otherwise guys like eagle claw did his both from the back, MAP's FDSM has 4, with some crazy ass tubing stuff off the top.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 02-20-2009   #3
All the random pictures I have saved. I think I'm going to go with a setup like the first couple pictures.
Old 02-20-2009   #4
Thanks Brad.
I want to go with a setup like the first one i want to use pushlock line on mine too.
Old 02-20-2009   #5
Swifty1638
Swifty1638's Avatar
Wow, Brad did my work for me! Anyway, a few shots of mine as it sits:
Catch can, off MAP's FDSM:
Valve cover with the lines:
overall:
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 02-20-2009   #6
^what size lines are those?
i want some good size line so i don't have to worry about it.
Old 02-20-2009   #7
I might need a good vented setup, what catch cans you guys using/modding?
Old 02-20-2009   #8
I got an ebay one that i will be welding the right size pushlok fittings to.
Old 02-21-2009   #9
Swifty1638
Swifty1638's Avatar
mine was made by jmf. as for line size it is ~8. You really won't need much bigger then that. I'm trying to decide if i need a re circulation line from the catch can to my new intake pipe.
Black 1GB Mafia #1
I wanna go fast.
