Old 05-26-2009   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
1g hard to get in to gear when running
hey guys i was driving around tonight and it started to get hard to get in to the gears all of them are nearly impossible to get into when running but when i get the car rolling i can get in to 2nd-5th reverse is hard to get in to but i can get it in but it sorta wants to grind ... it just started to do this tonight so im trying to figure out if its the clutch or something why would it go in to gear nice if the car is off ... its like im not pushing in the clutch in all the way .. so what do i do all greatness on this site ... ?
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 05-26-2009   #2
Gravy
Who's this guy?
Re: 1g hard to get in to gear when running
Quick check you could do, is make sure the bolts are tight on the shift linkage cable. Mine came loose before and did the same thing.
Old 05-26-2009   #3
Try the clutch adjustment screw at the pedal? Turn the screw away from the pedal and see if it helps any, maybe the clutch isn't disengaging 100%. Though I'm not sure why this would just start happening.
Or have someone check to make sure the slave is moving in/out. Maybe it's the master or slave going bad.
Old 05-26-2009   #4
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
If it just started happening I would suspect your clutch master cylinder is going out or is low on fluid, or needs to be bled. There are a number of other things as well that could cause this.
Old 05-26-2009   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
If it shifted fine before and now it's getting worse I wouldn't adjust the pedal. I can almost garentee it's the slave on it's way out. It always gets hard to shift a couple days before it actually goes out on you.
-1990 Mitsubishi Cyborg 4WD-
Old 05-26-2009   #6
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
maybe your tranny is falling off?
maybe your clutch disc fell apart/is falling apart?
was it instantly noticable? Did you do something right before this happened?(beat on it or something)
'04 Honda Ricer: stock
Old 05-26-2009   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Check for slop in the clutch pedal assembly, it's very common
Old 05-26-2009   #8
+1 on all of the above, but my bet is on slave cyl.
Old 05-26-2009   #9
jhaan_dude
jhaan_dude's Avatar
Drives: a car
check the fluid level...?
Old 05-28-2009   #10
Shifter cables, they are common to wear out, 2nd/5th/Race is when you are pushing the shift linkage forward in the tranny, thus a bad cable will bend and not go all the way into gear.
Old 05-28-2009   #11
way2fastalon
IS Broken :-/
well found out the trans bolts are loose so every time i push the clutch in it moves the transmission out so i think thats whats wrong .. lol
+more mods to list
Old 05-28-2009   #12
That is what you call a severe problem.
