Old 08-18-2009   #1
The 92 Laser
The 92 Laser's Avatar
Drives: Turbo Miata
Stowing a motor Need Help PLEASE!!!!!!!!!
So I recently picked up a built motor for a sweet a$$ deal. Issue is Im deployed. Im home for 2 weeks of leave right now. I should be getting the motor in the next couple of days. I will be stowing it in a climate controled storage unit. The motor will be sitting for 6 monthes. The block and head are seperated.
Now for the questions.
Should i keep them seperated or put the head back on?
How should i cover it?
Put oil, lube or any kind of grease on it to keep the parts fresh?
Any input will be awesome.
Thanks Ross
The 92 Laser is offline   Reply With Quote
Old 08-18-2009   #2
Re: Stowing a motor Need Help
Assembly lube or fogging oil + plastic trash bags to keep everything protected. 6 months really isn't that long though, especially if its in a climate-controlled environment. A light coating of fogging oil should do a nice job keeping rust away.
Old 08-19-2009   #3
The 92 Laser
Drives: Turbo Miata
So i got the motor today. It is seperated the head is of and so is the oil pan. There is debris on the inside of the block. So Im in a big pickle. So what should i do leave it and worry about it in six months? Have it cleaned and put it back together? Can i keep the block together and clean it or does it have to be full disassembled to have it cleaned? I know if it is hot tanked it has to be full disassembled. Basically im asking if there is anyway i can clean it without having to take the block apart? Any help would be great?
Old 08-19-2009   #4
What type of debris?
Old 08-19-2009   #5
The 92 Laser
Drives: Turbo Miata
Like little bits of styrofoam and most like dirt and shit
Old 08-20-2009   #6
Well, to be on the safe side you should probably tear it down and clean it. Why did you buy this?
Old 08-20-2009   #7
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
I think you'll be fine, just follow Kracka's advice. FWIW, I had my block & head sitting for well over 1 year.
Avatar = Small Turbo:confused:
mukapahnpy is offline   Reply With Quote
Old 08-20-2009   #8
The 92 Laser
Drives: Turbo Miata
Cause he had over 5,000 dollars done to the motor with only 100 miles on it and he sold it to me for 1700. I knew when i was buying i was going to aleast have to drop a grand into it to get her back up in the game.
Old 08-20-2009   #9
4seasons69
4seasons69's Avatar
its better to be safe than sorry. it's not in a car, the heads off, it isn't hard to tear the rest down and clean it just to be safe
Old 08-20-2009   #10
I would still tear it down and inspect it. I bought a built short block that I was told was in running condition, but once I tore it down I found two bearings had spun because they were installed backwards. Better to be safe than sorry.
Old 08-20-2009   #11
I have heard too many stories where a person buys a motor that was supposedly "built" or ran properly according to the seller, only to have it fail a couple hundred miles later. Better be safe than sorry, I would clean it up as long as its out of the car.
Old 08-21-2009   #12
The 92 Laser
Drives: Turbo Miata
Yeah Im just gonna pay someone to look at it and assemble it. Im only home for another week before i go back to Iraq so i need to have some fun plus i got the money why not spend a little.
Old 08-21-2009   #13
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
damn ross, when you going to be back for good?
