Old 04-07-2009   #1
95talonracer
95talonracer's Avatar
Alot of 1g & 2g Parts For Sale
DSM Parts
Need to sell these parts ASAP so I do not have to bring them with me when I move.
Send me any reasonable offers!
1g grey leather seats with matching door panels
1g dark grey door panels driver and passenger
1g center consol carpet
1g auto transmission transfer case
1g intercooler
1g rear passenger tail light
1g stock floor mats
2g fwd driver axle
2g awd passenger front axle
2g radiator
2g talon passenger tail light
6 bolt 2.0 block
6 bolt 2.4 block
Here are more parts for sale. Just send me an offer.
1g---
6 bolt timing belt >500 miles
plug wire cover
harmonic balancer
dip stick & tube
front seal housing
tensioner arm and motor mount
timing pulleys
Lower crank timing belt sprocket
1g Non Turbo Throttle body
plug wires
transistor
o2 housing gasket
exhaust mani gasket
fuel rail
FPR fuel pressure regulator
manual 91+ shifter assembly
driver mirror
throttle position sensor
awd brand new rear rotors
valve cover bolts
gauge cluster with 112K miles
flip up headlight bulbs brand new
delta gate 38mm wastegate needs seal
90 awd 4 spyder center differential
flip up headlight assembly with bulb
radio trim
cup holder
flip up headlight motor
flip up headlight trim
stock boost tubing
2g---
center vent with switches
radiator hose
97+ turbo ECU
Plug wire cover
stock fuel line from filter to rail
harmonic balancer
stock fuel pump
maf sensor extension wire
shift fork
front seal housing
timing pulleys
Random brake pads with very low miles
transistor
turbo water pipes
o2 housing gasket
manual shifter assembly
speed sensor
stock throttle body with lower sensor
gauge cluster trim
Infinity stock amp
thermostat housing
starter
dual piston front calipers
aftermarket rear muffler
High flow magnaflow 3" cat
Amsoil Dealer
Old 04-07-2009   #2
Re: Alot of 1g & 2g Parts For Sale
Can you send me pics of the 1g door panels? thanks.
mbgoodhart@msn.com
Old 04-07-2009   #3
Ryze
Drives: 98 Dodge Neon, 93 GSX Race car
$50 on the magnaflow cat??
Ryze is offline   Reply With Quote
Old 04-07-2009   #4
95talonracer
mbgoodhart@msn.com
I dont have any photos but they are in perfect shape and I think all the switches are even still there. PM me if interested with an offer.
Amsoil Dealer
Old 04-07-2009   #5
95talonracer
Sure when do you want it?
Amsoil Dealer
Old 04-07-2009   #6
Shit, I forgot to ask. Are they for power windows and locks?
Old 04-07-2009   #7
95talonracer
Yep!
Amsoil Dealer
Old 04-07-2009   #8
Ryze
friday work for you??? i have the day off then
Old 04-07-2009   #9
95talonracer
Sure does.
Amsoil Dealer
Old 04-08-2009   #10
If Goodhart backs out of the door panels I'm interested. I'm also interested in the floor mats.
Old 04-08-2009   #11
95talonracer
Who ever gets them first. I need the stuff gone. $50 takes both door panels and you can have the mats with the panels.
Amsoil Dealer
Old 04-09-2009   #12
Stinger2G
Stinger2G's Avatar
Drives: 99 Eclipse Turbo Sold*99 subie Winter Baby
hey Kerry buddy!!! I still have the bad 6 bolt crank you sold me. Remember u said ur gonna give me my money back!! Well I'm still waiting on it. I hope you aren't planing on takeing off without givin my money back. good luck on the sale.
Stinger2G is offline   Reply With Quote
Old 04-09-2009   #13
95talonracer
dude give it up! I have more people to back me up on this forum then you even know on here. I had that crank inspected by a well known motor builder on here by the name of motors by gosh. the crank was turned, inspected, measured, and hot tanked ready to be used. what you did to it 3 months later after I sold it to you is your deal. back on subject. as of right now the door panels are spoken for and are being picked up tonight. need to sell everything so send me a pm on what you want.
Amsoil Dealer
Old 04-09-2009   #14
rocket2g
Drives: 2g
is that ecu eprom
rocket2g is offline   Reply With Quote
Old 04-09-2009   #15
95talonracer
Originally Posted by rocket2g View Post
is that ecu eprom
nope this is a 97+ and mainly only some of the 95 ecu's were eprom
Amsoil Dealer
Old 04-09-2009   #16
Stinger2G
Stinger2G's Avatar
Angry Re: Alot of 1g & 2g Parts For Sale
Dude I had the crank inspected at MAP by their engine builder the crank was nothing but bad news. Every thing you said about the crank was a lie!!! The crank needs to be machine and the key way need repair.
Old 04-09-2009   #17
95talonracer
Well either you fucked it up or it isnt the same crank because I had just got it back from the machine shop before selling. If this was the issue then why wouldn't you say something right away and not wait over 3 months??????? even if it was perfect MAP would never install a turned crank for a customer anyways so of corse they are going to tell you things like that. Now stay the fuck out of my for sale thread.
Aftermarket 3" cat sold, thanks ryze! Let me know if you have any issues. Door pannels being sold on friday.
Amsoil Dealer
Old 04-09-2009   #18
Stinger2G, unless you're interested in buying something any more posts in this thread and you'll be sent on a pleasant vacation. Take it to PMs if you have an issue with 95talonracer.
Old 04-10-2009   #19
Stinger2G
Stinger2G's Avatar
PM send
Old 04-11-2009   #20
95talonracer
PM send
Dude stay the FUCK out of my fucking for sale thread if you have no interest in buying my parts. How fucking hard is it???????????????
Door panels sold.
Aftermarket cat sold.
2g fwd driver axle sold.
Amsoil Dealer
