Old 08-11-2009   #1
Forced Fed
Drives: FS-T
What is this product all about? DEI CryO2 Cryogenic Air Intake
http://www.maperformance.com/dei-cry...ir-intake.html
Was farting around on your website and I was wondering if you can tell me anything more about this product other than what your description already told me about it.
Old 08-31-2009   #2
AWD-DsMeR
Drives: 95 eagle talon tsi awd
Re: What is this product all about? DEI CryO2 Cryogenic Air Intake
same question. an answer please?
AWD-DsMeR is offline   Reply With Quote
Old 08-31-2009   #3
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Seems to me like a co2 injection system that lowers the air temps going into your cold side of your turbo.
Old 08-31-2009   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Weirrrrrd
-1990 Mitsubishi Cyborg 4WD-
Old 08-31-2009   #5
Constant_Project21
Drives: E36
Sounds intresting, i'd like to see the gains if any.
Old 08-31-2009   #6
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Put it on Brad's car. Maybe it will pass the 600awhp mark. haha
Old 09-01-2009   #7
v8klla
v8klla's Avatar
Sorry I missed this guys, basically it acts as an intercooler that cools the intake air via CO2. Pretty cool idea but not much surface area so I'm not too sure how well it works...
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 09-01-2009   #8
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
"Multiple units can be used for colder results." This means you can put 5 together for some really cold air!
7/25/09
Old 09-01-2009   #9
So does this spray co2 into the intake charge, or is it like a thermos where there is a boundary between the co2 and the intake air?
Old 09-01-2009   #10
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
better to just spray Co2 on ur front mount, lots of surface area there!
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 09-02-2009   #11
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
You cannot spray CO2 into the air entering the engine as it isnt flammable. So it flows through the center of that cone thing in the center and makes it cold, drawing the heat from out of the air passing over it. Then the spent CO2 exits a dump tube, much like a nitrous purge.
As far as spraying it on your front mount, I used to do this, but you will go though a whole 10lb nitrous bottle full in just a matter of 20 seconds or so (at least I did). What I did instead was go to ACE Hardware and get a pressure washer nozzle (about a 45 degree spray patter if I remember correctly) and rig it to my window washer tank, fill with water and have it aiming toward the intercooler. So as I was racing I'd be covering my hot front mount with cooler water. Cooling effects much like a runner dumping a glass of water on self to cool off. Not to mention water is free to refill.
In my opinion these would be a huge waste of money as it looks to be a major restriction in the intake piping (no matter the shape), Spend your money on a meth injection kit and make some real power.
Mwolf83 is offline   Reply With Quote
